Revelation about 9-bolt axles
Old May 11, 2001 | 12:30 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Recently I posted that I checked the 9-bolt axle part numbers at the dealer, and they were the same from 85-89. So I thought since 85-89 10-bolts are 26 spline axles, I figured 9-bolts were 26 spline axles too. Well guess what I found out yesterday? 9-bolts are all 28 spline axles!! I pulled one out of a 88 today, and counted 28 splines. And since the part numbers are the same, all 9-bolts must be 28 spline axles too. Yet another reason why 9-bolt rear ends are stronger than 10-bolts.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old May 11, 2001 | 01:58 AM
Like a ROC 89's Avatar
Cool...now if we can only get the prices of our gears and posi down it would be a great rear to have... BTW anyone know where to get a set of series 2 gears for the 9 bolt that are around 3.45??
Old May 11, 2001 | 09:31 AM
blak92!'s Avatar
I have the opportunity to get a 9 bolt from a 1988 GTA 5.7L 350 hard top. I am curious whether this is a 3.27 ratio or worse 2.77. I have not been able to locate the RPO codes in the glove box, I guess I have to check the hatch area.
Is the 2.77 the same carrier as the 3.27?
If so I plan on installing the 3.70s.
I am probably going to spring for the Dana44 if this 9 bolt is a 2.77. My rear is holding me away from using the camaro at the track for some new times- becoming extremely impatient. 8)~
Hybrid Black 5.7L 5 Speed
'95 Competition Yellow Corvette Coupe ZF6
Old May 11, 2001 | 01:27 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
That has been stated before. 28 splines on all of the 9 bolts. Plus, they have 4 pinion gears mating with 2 side gears (instead of 2 and 2), which makes them stronger.
<font face="Verdana, Arial" size="2">
Cool...now if we can only get the prices of our gears and posi down it would be a great rear to have...</font>
It's almost done. They won't be as cheap as 10 bolt stuff, but the selection will be there (up to 4.11's).
BTW anyone know where to get a set of series 2 gears for the 9 bolt that are around 3.45?? </font>
There isn't any, but new series 3 carriers are on the way soon.
</font>
Nope. 2.77 is series 2 and 3.27+ is series 3.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES,it is a 9 bolt & YES they are 3.73's, not 3.70. 4.11's to follow soon )
www.koolmeister.com
Old May 11, 2001 | 09:20 PM
snakeskinner's Avatar
"stronger" yet the only people I know that have shelled gears were 9-bolt cars. hmmmm... Plus, when they go out you're screwed. it's cheaper to buy a whole used rear than a new set of gears....IF....you can find them since GM discontinued them. p.s. I have a 3.45 disc setup forsale $500
Kyle Osterholt
Okarche, Oklahoma
ASE Master Certified
86 T/A 383 TPI
89 TTA #1002 T-top/Leather
89 TTA #1358 Hardtop/Leather
80 T/A Pace Car
73 Opel GT
73 bronco
Old May 11, 2001 | 11:46 PM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
</font>
Just because GM discontinued them does not mean parts are not available! (meaning gears up to 4.11, series 3 carriers and other goodies.)
PS For $500 I can get two 10 bolt 3.43 rears. Hmmmm... I wonder which one is better.
Miles
88 427 Camaro
www.koolmeister.com
Old May 12, 2001 | 12:27 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
umm, in case you don't know about them, 10 bolts also came with 28 spline axles. it began in late 88.
Old May 13, 2001 | 11:34 PM
Kevin91Z's Avatar
Zippy, check your part numbers again. The 10-bolt uses the same 26 spline part number up to 1989. In 1990 the part number changes, which to me means 1990+ uses 28 spline axles.
9-bolt parts are still plentiful and available in Australia. But shipping is a problem...
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
Old May 14, 2001 | 11:35 PM
zippy's Avatar
Engine: 5.3L
i actually have checked the numbers. according to our part numbers at work 4.3 s10's with stick, astro van's, and late certain v8 camaro's in 88 with 10 bolt got 28 spline's. it wasn't on all until 90.
Old May 15, 2001 | 09:28 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Kevin, they started changing over the 10-bolt axle splines in late 88; some applications, probably the high volume fast movers like the 2.73 drum setups would have been the first ones to get the new parts. 89 is the worst year, there were some of the old ones still mixed in with the new ones in their stock, so there's a mixture of them out there. The changeover wasn't complete until sometime in 90.
Besides the number of splines, what is the axle diameter in the 9-bolts? That changed along with the spline count in the 10-bolts: the 26-spline axles will slide right up into a 28-spline carrier, without engaging of course.
ICON Motorsports
Old May 15, 2001 | 10:10 AM
MY87GTA's Avatar
I have a 9 bolt with 3.73 gears from Reider Racing, they carry all the parts you'll need. They have a website but it doesn't list all the stuff they have, you'll have to call them.
cheesehomer
Dec 31, 2015 08:48 AM
dustint209
Nov 26, 2015 12:28 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
usafirebird
Sep 29, 2015 11:58 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
