Undercoating removal? Possible?
The only method I've heard of is... a screwdriver or paint scraper. Have fun!
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
T56 - SIX-speed
open 3.73's
2 1/4 stock catback
I love pissing those LS1's off
My Formula
All your base are belong to us.
88 firebird formula
350 Vortec TBI
Edelbrock headers
T56 - SIX-speed
open 3.73's
2 1/4 stock catback
My Formula
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Undercoating should be outlawed on sports cars... my IROC unfortunately has it
I have been able to scrape some of it off, it also helps to heat it up a bit with a propane torch....you just got to be careful what all you are heating up
Did you try a wire wheel on a drill? That's what I plan to do when my POR-15 time comes.
1984 WS6 Hardtop Trans Am
Former L69 Car under restoration
1984 T-top Trans Am
4-bolt main 350, performer intake, headers, Holley 650, T-5, hayes clutch, dual elec. fans and 3.23's.
Daily driver and restoration
13.98 @ 101
1984 T-top Trans Am
13.98 @ 101
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Propane torch and a putty knife is the best way. I still need to do that to my race car. I don't need the extra 40 pounds of undercoat.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.69
Best MPH on a time slip: 121.52 altitude corrected to 127.76
Altitude corrected rear wheel HP based on power to weight ratio: 504.5
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
Good luck getting it off but I am slapping on another coat. That is the only reason my car still has a floor in it. I love the stuff because all the cars rot so fats with the salt air and road salt.
91 Z28 Camaro
305 TPI
Flowmaster 3" exhaust
700R4 with 2000 Stall and shift kit 3.42 rearend
One sweet sounding system
91 Z28 Camaro
305 TPI
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Huh. The undercoating on my car dissolves quite nicely in gasoline.
There's also a commercial undercoating remover. I've seen it advertised once, but for the life of me I can't remember where, or even what it was called.
Fastbroker: I found out about the "dissolves in gas" quite by accident, I assure you.
My engine crossmember was undercoated, and everytime I mess with the AFPR (which is mounted about where the mechanical FP would be) it spills gas all over.
My engine crossmember was undercoated, and everytime I mess with the AFPR (which is mounted about where the mechanical FP would be) it spills gas all over. I don't think my car had a undercoating on it. What color is the coating and the texture of it.
just courious
97 formula w/6speed,cags skipshift eleminator, hurst billet pro shifter, 30#injectors,adjustiable fuel presure regulator,Moroso cold air induction,ported mass air sensor,accell300+ ignition box, accell 9000 wires, bosch platnum4 plugs,flomaster crossflow muffler,Lingenfiter 52mm throttle body,TPIS L98 SuperProfile cam,Crane 1:6 full roller rockers,Edelbrock subframe connectors,Edelbrock strut tower brace.
Other car is a 89 GTA w/700r4w/stage 2 shift kit, corvette servo, B&M mega shifter, TPIS bigmouth intake, TPIS large tube runners, TPIS 52mm throttle body,Edelbrock ported centerbolt heads,LT1 24# injectors,GMPP LT4 hotcam,CompCams Pro magnum roller rockers,Edelbrock headers, flowmaster crossflow muffler,MSD 6A, accell coil, bosch platnum plugs, this car is currently under rebuild and restoration.
just courious
