Rear crankshaft leakage
Old May 15, 2001 | 11:31 PM
BigChevy342's Avatar
Hey guys,
i got a question, My 91 cheverolet p/u is leaking where the crankshaft is on the back of the engine, I guess its called the rear main, or the one piece seal? Anyways, my truck is a 5-speed and im pretty sure the oil is getting on the clutch, which is probably why i just changed it and it was sort of glazed. Can i pop a new seal in there without pulling apart the engine and taking out the crankshaft? If not, is there some sort of a temporary fix that has been developed?
Old May 15, 2001 | 11:54 PM
Jester's Avatar
Thats the rear main. In a 91 it should be one piece, as opposed to 2. IT can be replaced, but it's a pretty big deal. I *think* for a one piece you have to pull the tranny, clutch and flywheel. You'l also have to pull the starter, jack up the engine, drop the oil pan, and then change the seal.
There really isn;t a temp. fix.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old May 16, 2001 | 08:36 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Jester is correct except for one thing...you don't have to lower the pan and jack the engine on a one piece seal.
They just pop out like an axle seal. Just be real carful when re-installing, you don't want the "lip" of the seal to fold over when pushing it back between the crank and block.
I lube the inside of the seal real good but don't put anything on the outside of the seal.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
383backinblack
Aug 15, 2015 06:36 PM
BBSDesigns
Aug 11, 2015 07:39 PM
