Fastburn Heads
Old May 16, 2001 | 08:10 PM
scott87conv's Avatar
Fastburn Heads
Is it logical to use fastburn heads in a everyday driver(still want a chance at emissions)or should i just try a good performance head. Thinking about edlebrock rpm heads.Help please???
Old May 16, 2001 | 10:20 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I presume you have a 305. The fast burn heads are the corvette aluminum heads with a 58cc chamber. From what I've heard these will perform well on a 305. Vortech305 and Willie both use them and have seen good results.
Robert
1987 IROC-Z Auto (LB9)
Black/grey interior with the stance of a streetfighter
I like to think of her as Arnold Schwartzeneger in a dinner suit
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat. K&Ns, AFPR and Air foil.
Future mods:
Cam change
New torque converter
New heads (maybe corvette L98)
Strut brace
Sub frame connectors
Ram Air
Current G-Tech times
0-60mph 6.26 seconds
1/4 14.74@100.2mph
Old May 17, 2001 | 09:29 AM
Will these heads effect the emissions a great deal and are all fastburn heads corvette heads???
Old May 17, 2001 | 10:16 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Fast Burn heads and L98 heads are totally different. Nothing in common.
http://www.paceparts.com/fast_burn_cylinder_head.htm
They are not practical as a bolt-on for an otherwise stock 305, but might be OK for a properly set up 350. Plus, as you can clearly see, there's no exhaust crossover passage, therfore no EGR unless you get the Vette external setup for it, although it might be possible to install one. I don't know if that matters to emissions testing in your area.
ICON Motorsports
Old May 17, 2001 | 10:19 AM
Thanks RB83L69 & RMK
Old May 17, 2001 | 10:37 AM
FormulaJoe's Avatar
Not the same head at all. Even though they dont have all the smog equip in the heads, they may pass a sniff test just due to the fact that they have a VERY efficient combustion chamber. On a properly tuned EFI motor and a stock or mild cam, you could probably pass a sniff test at the tail pipes. Again, I have no hard data to back this up, but Ive seen worse past sniff tests.
L98, 3.27 9-bolt, Hooker shorty headers, custom 2.5inch Y-pipe, no cat, 3inch 2chamber flowmaster, JET AFPR, Ported MAF, Best ET: 13.86 @100mph. 1.99 60'
17 inch ROH "ZS" wheels. 17x8.5(front) and 17x9.5 (rear). Firestone Firehawk SZ50s. 245/45/zr17s and 275/40/zr17s. T56
On the way... Radar Blue 89 Formula, T56, Ram Jet 430, Ram Air, 17inch ROHs.
Old May 17, 2001 | 10:40 AM
I have a carb and i am changing the 305 to a 400sbc. Who makes a good set of fastburn for a everyday street car???
Old May 17, 2001 | 11:40 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The only mfr that makes Fast Burn heads is GM... it's a trademark
What are you really asking? Do you want to know what a good head might be for some particular application? If so, tell us more about what you're trying to do and maybe somebody can help you out.
ICON Motorsports
Old May 17, 2001 | 12:38 PM
Well i want a 400+ street motor(400sbc)that can pass the exhaust test.I am changing stock ignit. to MSD(everything)and i am changing my gears from 2.73 to 3.73. This will be a daily driver summer only.I have a 700R4 trans and will be adding a B&M shift kit,2400 or 2800 stall.It had a stock electr. carb and i am looking at a demon. Alot of the parts i have already, want to get everything done at once as far as the engin goes. Any suggestions????? please
Old May 17, 2001 | 01:40 PM
Formula-91's Avatar
<font face="Verdana, Arial" size="2">Originally posted by RB83L69:
</font>
Yep, but other companies are already copying the combustion chamber design. The Sportsman II heads have what they call a "Fast Burning" chamber. Essentially the same chamber design as the GM FastBurn head.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
