Fastburn Head Clearance issue?
Old May 17, 2001 | 10:31 PM
buddha6974's Avatar
Does anyone know if a fastburn head will bolt to a lg4 <definitely not stock>?
ive heard that the valves are too big for the bore and may hit causing MAJOR problems.
my cam is not stock but i don't have the specs on me here. i also plan on running 1.7 rockers.
it is a track only vehicle, and i want to go as far as i can with a 305 until my 502 is ready. <money is a non issue as i have time>
thanx
dan
i got an 84 camaro, shes got a 89 mustang. which do i have to work on more?
Old May 17, 2001 | 11:10 PM
steve8586iroc's Avatar
Don't do it, use ported L98 vette heads, there cheaper and will work better on a 305. You will have as much air flow as you need but not too much as you would have with the fastburn heads. Your compression wouldn't change either.
Steve
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Feb 28, 2016 03:33 PM
bamaboy0323
Sep 3, 2015 06:07 AM
86White_T/A305
Aug 17, 2015 12:16 AM
anesthes
Aug 8, 2015 09:37 PM
