engine swap: electrical woes...
Old Oct 5, 2004 | 07:16 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
my car will start when the voltage reads low, then if it dies, or you turn the key off, thats all she wrote. If you jump it after a few minutes charging it'll start again, but its not building juice. I'm not completely sure if i wired everything up correctly after the swap, my sig says what i'm running...
grounds:
wired the negative battery cable to the passenger side head
the skinny firewall ground to accessory bolt at the back of the head
tiny wire off the negative is at the fender....
the red wire off the positive cable goes to the starter, along w/ the thick purple and red wires from the harness.
I put the red wire off the alternator on the starter too, is this correct? The black wire w/ the red line goes to the postive cable as before... the two brown wires w/ the white stripes, what do those go to?
the alternator belt could be tighter, but it spins the alternator.
the battery is new, but since i didn't have the alt. plugged in properly for a few days, its on the charger.
the alternator as well as the rest of the system, never moved from a hair below 13 volts w/ the LG4 before. the alternator sat 3 or 4 weeks, waiting to go back on the 350HO.
do you guys see anything fishy w/ my setup?
I'm thinking this is all pointing to a bad alternator, but I'm just a novice when it comes to troubleshooting cars... I'm learning!
thanks,
brandon
Old Oct 5, 2004 | 08:22 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
There should be a two wire connector that goes to the side of the alternator. If this is not hooked up, the alternator will not work.
Old Oct 5, 2004 | 09:45 PM
Tobias05's Avatar
it seems one of those go to a fuse or relay box, the other goes to the drivers side harness.
Old Oct 6, 2004 | 06:27 AM
Tobias05's Avatar
Re: engine swap: electrical woes...
Originally posted by Tobias05
grounds:
are these ok, or do i have something backwards?
Old Oct 6, 2004 | 07:51 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
sounds like you have those grounds correct. where do you have the brn wht wires connected. as said these have to be right or the system will not charge.
Old Oct 6, 2004 | 08:43 AM
Tobias05's Avatar
originally, not knowing what they went too, i had cut them out
i spliced them back together, i made sure to leave enough wire there in case i cut something out i needed, i could wire it back in.
one of the brn wht wires is connected back to the harness, the other seems to go to a fuse box or something right above where the harness enters the cabin, on the drivers side.
hope this makes sense,
brandon
Old Oct 6, 2004 | 06:24 PM
Tobias05's Avatar
fixed... and i feel like a dumbass
ok... one wire was light brown, the other was a dark tan w/ a white stripe... i had re-wired them backwards....
I'm with stupid....
brandon
Old Oct 6, 2004 | 06:41 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
haha it happens, at least its fixed and it was something simple.
Old Oct 6, 2004 | 06:44 PM
Tobias05's Avatar
true, the simple things make your mind spin, then you start thinking you need new parts, lol...
Old Oct 7, 2004 | 07:01 AM
Engine: 406
Glad you got her figured out. I wired my starter wrong on my second swap..heck I even had the wires labled. Took me about 2 days to figure out what I had done.
Old Oct 7, 2004 | 12:39 PM
ljnowell's Avatar
Hey just a quick question since this thread is already open, instead of starting a new one. I did the v6 to V8 swap in my car, and since I have went through 2 batteries. Now dont get me wrong, these are junk Everstarts (neverstart) from WalMart. I have all of the stuff hooked up the same as above. But the two wires that are off of my alternator are red and black. Its one of the old style with the spade connector. My question is, where should each of these go to? I just want to make sure that I have them hooked up right. I may have the colors off a little too, I am color blind (damn these eyes ) If anyone knows,they could tell me by the pin they connect to.
Ikes 91Z
Dec 9, 2015 03:49 PM
lakeffect2
Aug 23, 2015 08:44 AM
TheExaminer
Aug 19, 2015 10:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
