Need help .... gas level.
Old Oct 5, 2004 | 11:44 PM
90tbi305's Avatar
Car: 1990 350 tbi l98,
Engine: 5.7 tbi
Transmission: t5
I recently changed my fuel pump on my 90 tbi 305 camaro and sence then have had a weard problom. At first, lets say i was on empty and put in $27.00 of gas to fill up my tank (about 14 gallons), it will take about 15-30 minutse of driving for the needle to go up. I would drive and the needle would go up little by little every time i hit a hard turn, on till it reaches to 1/4 tank ,from there on it will go to full tank. This problem was happening for about a month.
About two days ago the gas needle was a little over 1/4 tank, and didnt see the gas gauge go up or down when i give it gas or step on the brakes. About 5 minutes of driving my car turned off and didnt want to start on because of no fuel.
When i changed my (stock replacement fuel pump) it brought some type of little clips to connect to the electronics that the wires had and didnt do it. Can that be the cause of my problem?
Need help, i really dont want to stay stuck on the road again.
-Thanks eric.
Old Oct 6, 2004 | 12:14 AM
sellmanb's Avatar
Car: '86 Berlinetta
could you please clarify on :
the stock replacement had wires that you didnt connect, or the newest one does? Either way, why didnt/dont you connect them, they're obviously of use to something lol...
As per your weird 1/4 tank thing, there's a float inside the tank i believe, did you mess with the float at all?
Old Oct 6, 2004 | 09:33 AM
90tbi305's Avatar
Engine: 5.7 tbi
Transmission: t5
Of course i connected them if not the fuel gauge wouldnt work, but there was some type of little connector that it brought but i didnt put it in because i thought it wasnt bad. i didnt really mess with it i just changed my fuel pump and put it back in.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
86maro_252
Oct 10, 2015 06:52 PM
kx3g
Sep 28, 2015 08:14 AM
reactor60
Sep 22, 2015 01:44 PM
ULTM8Z
Sep 16, 2015 09:15 AM
