carb/crate & emissions
Old Oct 6, 2004 | 10:59 AM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
Can I pass emissions if I drop in a ZZ4 crate w/ carb? Has anyone done this and passed emissions or know what type of readings to expect? I know I should stick with the FI, but computers scare me, also $$ is an issue. My stock 182,000 mile L03 needs to be put out to pasture, I have enough trouble passing emissions with that motor as it is. I bet a brand new engine, even with a carb, will get better emissions numbers. What do you guys think?
Old Oct 6, 2004 | 11:15 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
In MA you have very strict emissions regs almost like CA. You need to find out what legally you can modify or if your car is exempt due to age or something.
I think that you have visuals and dyno testing. So you can't change the induction system or engine, IIR.
Old Oct 6, 2004 | 11:18 AM
Engine: 5.7, 5.0
I have had many cars inspected in MA and never had a visual check (except to make sure the exhaust was intact/functioning). I have never even had the hood popped. Just safety and dyno/emissions, thats it.
Old Oct 6, 2004 | 11:24 AM
Engine: 5.7, 5.0
I know legally I can't put a carbed engine in my car. It has to be an engine for that specific year or newer. But how can a tech tell what year your engine is? I'm not worried about the swap not being legit. I just want to know if it is posible to pass emissions with this motor.
Old Oct 6, 2004 | 11:44 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
So you have a 91? They you probably can't go carb. But if they don't have visuals, who cares as long as it passes dyno.
Old Oct 6, 2004 | 11:45 AM
Engine: 5.7, 5.0
My thoughts exactly.
Old Oct 6, 2004 | 02:17 PM
Engine: 5.7, 5.0
But is it posible with that engine?
Old Oct 6, 2004 | 05:21 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
It should with a proper tune. I would go with some Vortecs or Vortec copies ProTopline
They have fastburn chambers and are a more efficient design.
Old Oct 6, 2004 | 06:44 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
yup it'll pass the sniffer if tuned right and you keep cats on, my buddy did the same swap here in NJ and ended up with a carb due to lack of funds, just so its tuned right it'll pass just fine, just dont lettem see the carb. hehe
Old Apr 9, 2005 | 06:24 PM
parks911's Avatar
Car: 91 Camaro RS
Engine: 350 Police with some MINOR modifica
Transmission: kitted 700R4 & vette servo
Will the air pumps and exaust manifolds off a LO3 bolt up to a ZZ4?
Hotrodboba400
Dec 10, 2019 07:07 PM
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
TBRays98
Sep 6, 2015 05:05 PM
