If relocating the battery, MUST you install a cut-off switch?
Old Oct 8, 2004 | 05:35 AM
The Doc's Avatar
As the title says, if you are relocating your battery to the trunk MUST you install a battery cut-off switch?
If you don't race and don't have to meet NHRA requirements for an external easily visible switch that cuts all power, should you install one anyway?
Many thanks!
Old Oct 8, 2004 | 06:04 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
No, but it's not a bad idea and heres why. When you put the battery in the rear the wires are much longer and you increase the likelyhood of perhaps having the wire chafe causing a momentary short. With a battery guage wire the wire will begin to burn and eventually melt possibly causing a fire or the battery to explode. A cutoff sw right off the battery that you can get to quickly may just save the car. Up to you.
Old Oct 8, 2004 | 06:15 AM
ede's Avatar
ede
the reson you want a external disconnect is for safety crew or anyone stop fuel pumps in event of a crash on race track. stilla good idea to have one on any car just to kill power without having to unhook battery
Old Oct 8, 2004 | 06:39 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Do BMW's have a large inline fuse since they have the battery in the trunk from the factory, at least my friends older 3 series did.
Old Oct 8, 2004 | 07:17 PM
92GTA's Avatar
Firehawks do not use a cutt off switch and they were still IMSA and SCCA legal at the time of production...
Old Oct 8, 2004 | 07:29 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I think some tracks require a cutoff switch if the battery is relocated to the rear of the car, other than that, assuming you routed the wire correctly, there is no reason to install a cutoff switch....
Whatcha gonna do if you roll the car? Jump out and shut the battery off? If I can get out, I'm leaving the scene ASAP.
Old Oct 8, 2004 | 09:11 PM
ede's Avatar
ede
the battery cut off isn't for the driver to use, it's for safety people to use to kill power to car and fuel pump in the event there is a crash and the driver is trapped and say a fire fed by the fuel pump that's still running
Old Oct 8, 2004 | 10:02 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I realize that...that's why I mentioned some tracks require it.
But if you just doing it for weight distribution, there's no actual need to have one installed.
Old Nov 2, 2004 | 07:17 PM
The Doc's Avatar
Many thanks for all the comments guys!! Later this week I'll be relocating the battery and installing a cut-off switch as you suggested.
Old Nov 2, 2004 | 10:06 PM
Vader's Avatar
If you show up at the track with a 9-second C3 Corvette with the battery installed in the stock location, do you think they'll DQ you for NOT having a battery disconnect? They came with the "back seat" battery for over 15 years. I think I may have to get out my tire iron to "explain" that one to them if that occurred.
Old Nov 2, 2004 | 10:26 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
vader I have a question for you though
the z06 is capable of a high 11 stock if done right
if you are able to run a 11.98 wich is faster then the 11.99 roll cage listing
would I have to add one just to run my stock z06?
Old Nov 2, 2004 | 11:02 PM
Zepher's Avatar
11.49 or faster is the cage rule for IHRA (and I think NHRA as well). It could also vary by track as well.
Old Nov 3, 2004 | 11:01 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Hey Doc, where are you going to put your switch? If you need any pictures for an install behind the license plate I have a few for ya to look at.
Old Nov 3, 2004 | 11:16 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
It appears NHRA is going to adopt that for 2005.
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
89GTAOz
May 16, 2020 09:31 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
justin57
Aug 20, 2015 07:05 PM
