Come on L03!!!!!
Old Oct 10, 2004 | 12:14 AM
Gr89RS's Avatar
Car: '02 Z06
Come on L03!!!!!
Ok here we go....my car is i dont know the technical term but "sputtering" real bad while driving and the rpm needle keeps twithing.
I took the car in about two months ago and got the spark plug wires replaced...fixed the sputtering but not the guage...but for only a few days.
Then i took it in two weeks ago and got the cap and rotor replaced...same thing fixed sputtering ..not the guage..for only a few days.....Whats going on???? This all started two days i got my radio installed...even though i dought its even remotely related...could something electrical or in the computer be getting fried up?????
Please help its my daily driver!!!!!!!
Old Oct 10, 2004 | 04:14 PM
sellmanb's Avatar
Car: '86 Berlinetta
okay so:
you took it in to get the plug wires replaced? why didnt you do it yourself, it doesnt even take tools to replace your plug wires lol.
The cap and rotor takes a screwdriver, you coulda done that yourself too heh
question : did you replace the spark plugs as well? If not then you should, that'll more than likely be your culprit. If not then I'd have your ignition module tested.
I doubt that it had anything to do with your radio being installed... coincidence more than likely.
oh and just out of curiosity, how much did they charge you to do the plug wires, and cap and rotor?
Old Oct 10, 2004 | 08:56 PM
Gr89RS's Avatar
Car: '02 Z06
i just had the plugs replaced....60 bux for wires and 200 smackers for cap and rotor !!! ....How do i test the ignition module????
Old Oct 10, 2004 | 09:12 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
i really hope your kidding here....
thats rediculous to pay that much to change something that would only take you 10 min to do all of it ..LOL
Old Oct 10, 2004 | 10:07 PM
LnealZ28's Avatar
Car: 1987 Z28
Engine: 383 Single Plane EFI-NOW RUNNING!
Axle/Gears: Not there yet...
My money's on the ignition module.
Old Oct 10, 2004 | 10:10 PM
Gr89RS's Avatar
Car: '02 Z06
Other posts say something about a pickup coil and how it works with the ignition module..should i replace that while im at it and how much will the two parts cost????
Old Oct 10, 2004 | 10:25 PM
THEGENERAL's Avatar
here they are at autozone.....most parts stores are about the same on price
pickup coil ===http://www.autozone.com/servlet/UiBroker?UseCase=C001&UserAction=performMoreDetail&Parameters=TRUE%7C%7EPICK-UP+COIL%7C%7ENONE%7C%7EWELLS%7C%7ECAN+ALSO+BE+USED++++%7C%7EFALSE%7C%7EFALSE%7C%7E185215%7C%7E2616%7C%7EDR132%7C%7ENONE%7C%7E%2413.99%7C%7ECHEVROLET%7C%7ECAMARO%7C%7E1989%7C%7ENONE%7C%7E0.1%7C%7EEA%7C%7EB
ignition module ===http://www.autozone.com/servlet/UiBroker?UseCase=C001&UserAction=performMoreDetail&Parameters=TRUE%7C%7EIGNITION+MODULE%7C%7ENONE%7C%7EWELLS%7C%7ENONE%7C%7EFALSE%7C%7EFALSE%7C%7E84780%7C%7E2616%7C%7EDR140%7C%7ETO+TEST-%3E+LOCATE+PART+NUMBER+IN+WELLS+TEST+MANUAL%7C%7E%2433.49%7C%7ECHEVROLET%7C%7ECAMARO%7C%7E1989%7C%7ELLT%7C%7E0.15%7C%7EEA%7C%7EB
Jake_92RS
Jan 28, 2020 10:37 PM
beastin91rs
Oct 9, 2015 07:38 AM
anesthes
Sep 21, 2015 10:24 AM
Sharpcorner
Jun 14, 2001 12:58 PM
Tx92rs
Sep 16, 2000 09:27 AM
