My motor project is done! Check 'er out!
I finally got the motor/trans. swap done in my 1991 RS.
It used to be a 3.1L with an auto. It's now converted to
a 350hp 350 Ramjet motor with a T-56 trans. All I can
say is WOW! VERY different ride! I may want to go more
hp later on, possible supercharger with a retuned ECM.
May make it about 500hp. Max amount for this SBC!
Next on the list is some minor body work and detailing!
Let me know what you think!
Originally posted by rsn932
looks like a nice ride, great engine
lol whats that in the grill where a license plate could be?
Yeah, I blocked out where license plate was, just to cover
up the numbers. I edited the pic with my software, so it's
not acutally on the car. lol!
Thanks for the compliment too!
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
nice air intake tempature sensor
Why didn't you put it in the intake where it should be?
I really do like the ramjet intake and vortec heads setup though let us know if you ever run it on the dyno. I want to use fastburn heads and a ramjet intake in the future.
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
looks mean!!! does your hood close right??? i always thought that engine was to big for our cars, i mean to tall???? let me know
Car: 1987 IROCZ
Very nice! I would rethink the air intake and sensor myself, you would be better off putting the cold air intake stuff back on and relocating the temp sensor to the air box. The way it sits now, the best intake air your going to get is warmed engine bay heated air and that does make a difference. You might want to search on that and read for yourself what the negitive effects are, and there are lots of guys who did as you have and went back the other way as far as the air filter bolted to plentum. FYI
Car: 89 RS
Engine: 383 in building process
Yes it does fit. BUT, not without cutting away some of the
crossmembers in the hood. But once that was done, it fits
like a glove! Can't even notice the cutouts in the hood due
to the hood liner covering it all! So, yes the intake does sit
tall and I also used brand new poly motor mounts. Just
to let you know. If you plan on buying this intake system
or the whole crate motor, prepare for cutting away the
crossmembers in the hood to clear the intake. Otherwise,
invest in a nice fiberglass 2" or higher cowl induction hood.
Personally, the 4" cowl looks best on Camaros.
you mean). It goes as close to the intake air fiilter as possible.
I don't have the dual intake induction system for the V8. I
had a V6 before, and that system is too restrictive for this
new motor.
If anyone has a nice dual TPI intake system for me that's
in like new condition, PM or e mail me!
Thanks for all the input. Already know that colder air is
better than what I have now. Three reasons why I don't
have a cold air system or the dual TPI intake system:
1.) Don't have all the parts yet.
2.) Don't have the time to build a new one yet.
3.) I just finished this project as of last week, and I haven't
been shopping around much for the intake system. I have
been working out the bugs in the car which is more important
than the intake at this time.
So, there's your reasons.
Car: '86 Berlinetta
87Formula4bbl, your #2 spark plug wire looks a bit close to the header, hope yah realize.... or the picture is decieving
Engine looks great, both of you guys.
Car: 1989 Iroc-Z
Originally posted by Camaro_nut
Because it does not go in the intake manifold ( if that's what
new motor.
new motor.
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
VERY sharp, guys!!!
I love the RamJet smallblock setup :hail:
I would love to have one myself someday. That should run EASY 13s in the quarter
Originally posted by 87Formula4bbl
Looks great! Can't wait to finish mine up!
Ok, few things:
1.) Where did you get the wire loom kit from?
2.) Where did you put your IAT sensor to since
you are also not running an intake system like me?
3.) What type of headers are you running?
Car: '87 Formula
Sellmanb,
That pic is a little deceiving, the wire has plenty of clearance.
Camaro_nut,
Sorry, I didn't mean to hijack your thread here, I coudln't help but post just one pic tho
It's just so...so...sexy...Isn't it?
Anyhow, to answer your questions, the wire loom kit is a Made For You vertical kit for the old (perimeter) style valve covers, from Summit Racing. I'll be ditching those though, since I put my old (new style) center bolts on. I got sick of having seal leaks with those stupid adapter plates. I'll probably go with the Made For You center bolt type though, I like those looms a lot.
I haven't wired up an IAT sensor yet. I pretty much built that whole harness from the LG4 computer harness (which was way insufficient), so I have yet to add some more wires for the IAT sensor, injectors, IAC and possibly something else I'm forgetting at the moment. I really don't know yet what I will do for the IAT sensor. There is a 3/8" NPT fitting in the rear of the manifold but I was planning on using that for the brake booster. I think what I will end up doing is putting the IAT sensor in the intake track that I will probably build for a cold air setup. The headers I have are Hedman 1 5/8" shorties (no AIR). I'll be taking them out and recoating them again since I didn't do that well a job the first time around and they are starting to rust.
The engine bay is still a mess, since none of the wiring is in looms yet, but I'm close to being finished with the wiring, and everything is bunched together now and wrapped and ready for looms. I'm going to get the Summit billet alternator adapter also since there is no mounting location on this manifold for the stock bracket. Strut tower brace mounts are since gone. I've also fabbed up a bracket for the cruise (if anyone is interested to see how that works, I've got pics for reference) since I've still got the auto and plan to travel with the car. I'm pretty happy with the work I've done, now I just gotta get the engine bay painted nice like yours!:hail:
Camaro_nut,
ambainb
Apr 25, 2016 09:21 PM
