Going from R-12 to 134A
Old May 22, 2001 | 02:05 PM
wiggy'sIROC's Avatar
Car: 1986 IROC
Engine: 305 going to 355
My AC was last serviced in 1996 and and lasted about 4 days so I know I have a leak. Since it has not been serviced since then, what should I replace before putting in the 134a? I don't want to service it, find something wrong, fix it, reservice it and so on.
Thanks,
Mark
1986 IROC LG4 "Bone Stock" (for now)
Old May 22, 2001 | 02:27 PM
irocbsa's Avatar
You definitely need to find the leak. You can try charging it with the leak finder stuff they sell at the auto parts stores and see if you can tell where the leak is coming from. It could be from anywhere, hoses, compressor, etc. I retrofitted mine to 134 using a retrofit kit I got at autozone for 35 bucks. Its not as cold but 134 is not as good of a refrigerant as R-12 is, or freon as Dupont calls it. We can thank the environmentalist wackos for that.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
[This message has been edited by irocbsa (edited May 22, 2001).]
Old May 22, 2001 | 02:48 PM
Car: 1986 IROC
I guess what I am trying to get at is, if my system has a bad enough leak to go dry that quick, what components could go bad from lack of oil and refridgerant? I plan on changing all of the o-rings, the orifice tube, reciever/dryer, and whatever else you guys think of before I start looking for leaks. All suggestions are appreciated.
Thanks,
Mark
Old May 22, 2001 | 02:58 PM
85 T/A WS6's Avatar
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Transmission: Automatic
Axle/Gears: 3:27 Borg Warner
Take a look at your compressor clutch seal, those usualy go out, mine is toast and have to replace it soon, its getting too hot in WA!
Old May 22, 2001 | 10:45 PM
Bill86Z's Avatar
Try running around in West Texas, in a black camaro with no ac. Neadless to say, the t-tops come of very quickly
Old May 23, 2001 | 08:04 AM
Mark W. Winning's Avatar
There are a few additives to 134 now, that help make it a bit cooler. Its not a night and day difference, but mine dropped 5 degrees at the vent.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
diana227vegas
Jul 8, 2016 12:27 AM
apie2546
Sep 4, 2015 03:47 PM
iceman02
Jun 16, 2006 05:55 PM
GTAman
Jul 25, 2003 04:38 PM
George Khawahie
Jun 3, 2002 09:53 PM
