Tips for installing valves and springs???
Old May 22, 2001 | 12:20 AM
UVA3rdGen's Avatar
Ok so I have successfully removed the heads from my car and the valves and springs from the heads with little problems in about 6 hours. I was hopping all you gurus could give me some tips speaking from experience on what not to do and some other tips when reinstalling all the valve train. I been reading post about improperly installed valves and springs and that has scared me a little. What can go wrong? I followed the Haynes manual disassembly directions verbatim(maybe that was my first mistake). Thanks in advance and I sure hope all this porting and matching works.
Old May 22, 2001 | 09:33 AM
Guest
Guest
Posts: n/a
Well I hope you have them all in order, otherwise you are going to have to do a valve job.
Other than that, just stick the valves back in where they were at, put some new seals on them, and install the springs. I put some break in lube (you can use oil too if you want) on the valve stems, and the valve tips. Oil on the new seals is a good idea.
Old May 22, 2001 | 02:58 PM
UVA3rdGen's Avatar
Ya, I made sure to label all the hardware. So aslong as I do not nick the valve seats I can just put the heads back together and bolt the heads back on?
Old May 22, 2001 | 07:24 PM
Guest
Guest
Posts: n/a
Yep, thats all you have to do.
There is no reason not to replace the seals though.
Old May 23, 2001 | 02:09 AM
Bort62's Avatar
My question is, If your putting the Sam Valves and springs back In, Why Did you take it all apart in the first place ?
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 15.26 @ 87.0
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old May 23, 2001 | 09:29 AM
Guest
Guest
Posts: n/a
<font face="Verdana, Arial" size="2">Originally posted by UVA3rdGen:
Thanks in advance and I sure hope all this porting and matching works.</font>
He told ya Bort, you missed it
rocn7roc
Sep 21, 2021 02:16 PM
gta90
Sep 15, 2015 04:00 PM
sailtexas186548
Aug 26, 2015 03:32 PM
TheExaminer
Aug 25, 2015 07:34 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
