Camaro A/c Delete
Old Oct 18, 2004 | 09:19 PM
199225thrs350's Avatar
Car: 1992 Rs V-8
Engine: 8
Camaro A/c Delete
I deleted the smog system out of my 92' and I was curious as to roughly how much HP is free'd up at the Fly with both Smog and a A/C delete ?
Some pics of Smog delete , it worked out easily enough. Pep boys seemed to carry the belt I needed.
http://www.geocities.com/shotos_chaos/Camaro.html
Old Oct 18, 2004 | 11:23 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Approximately zero (0) HP from A/C delete.
Smog delete? hmm...3HP?
Old Oct 18, 2004 | 11:30 PM
Car: 1992 Rs V-8
Engine: 8
the one who created the post for a/c and smog delete was guessing some where around Hp at the crank , I was wondering if anyone has actually dynod before and after.
Old Oct 18, 2004 | 11:55 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
The A/C clutch disengages at WOT anyways, so its no more than a spinning pulley such as the A/C delete at that point. The main point of that delete is to free up space and some weight reduction...
As for the smog delete... who knows...
Old Oct 23, 2004 | 12:11 AM
EDDIETA_ZZ3's Avatar
Car: Trans Am
Engine: ZZ3 HO
Transmission: 700R-4
unless he removed the cats maybe 5-10hp max
Old Oct 25, 2004 | 10:12 AM
Keith5's Avatar
Car: C1500
Don't know about that, I took the cat off of my car after I did my mods, I put it back on the following year and the things runs much BETTER with a CAT. I gained power when I put a 2.5 inch Catco Cat on it. I went from running 83 to 86 mph in the quarter to running 86 to 87.5 mph.
My Et's also dropped and became much more consistant. I went from 16.2-16.9 down to 16.0 to 16.2.
It's very very consisant.
Old Jan 7, 2016 | 06:13 AM
87zeder's Avatar
Re: Camaro A/c Delete
get a decal made up "no a/c" it'll gain you 5 hp at the crank
Old Jan 7, 2016 | 06:43 AM
OrangeBird's Avatar
Car: 1989 Firebird
You needed to bump a 12 year old thread to post this , ahem , , "advice" ?
Frozer!!!
Jan 19, 2024 04:55 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
actionj
Carburetors
Aug 16, 2015 09:51 AM
BikeFarm
Aug 11, 2015 11:35 PM
