New intake and WP pics
Old Oct 18, 2004 | 10:26 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I replaced my intake manifold and water pump the other week, here are some pics. See if you can count the custom mods just to get these parts to work on the motor in accordance with the other parts!
Old Oct 18, 2004 | 10:28 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Attached Thumbnails New intake and WP pics-engine-right-side-smaller
Old Oct 18, 2004 | 10:32 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Modified intake, not need to work, just because i was bored.
Old Oct 19, 2004 | 03:17 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
This is how you get a Short water pump to work in a 3rd gen.
Attached Thumbnails New intake and WP pics-alternator-turnbuckle-small-lq2.jpg
Old Oct 19, 2004 | 03:34 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Whats up with your alternator? Thats friggin cool!!
Old Oct 19, 2004 | 03:39 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
On my left side head there was only 1 accessory hole, and my intake didn't have the bolt boss for the alternator bracket so i had to mod some stuff. To get the alternator to work i had to flip it over and but a turnbuckle on it for tension. I was kinda worried about it, but it turned out way better then i expected. The belts are just switched, the longer alternator belt is on the PS and the PS belt now drives the alternator.
Old Oct 19, 2004 | 05:00 PM
Air_Adam's Avatar
Did you need a spacer to make the alt. line up with the crank pulley? I really wanna try that! And what is that bolt on the adjuster threaded into? Under the water pump i mean.
Old Oct 19, 2004 | 05:49 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
No i didn't need any spacers. The bolt is a threaded rod that is threaded into the hole that goes into the fuel pump pushrod cavity. I threaded it in until it hit the pushrod, then backed it out a little. I then put a nut on it to hold it firmly against the block. Next i put a nut and washer on each side of the turnbuckle eye to keep it in place on the threaded rod.
Old Oct 21, 2004 | 02:59 PM
Air_Adam's Avatar
Cool, thanks
I might have to try that with mine.
stalkier
Dec 6, 2015 11:25 PM
1985chevydude
Aug 20, 2015 12:29 AM
cstrobel65
Aug 15, 2015 10:19 AM
Street Lethal
Aug 12, 2015 11:33 AM
Jake_92RS
Aug 11, 2015 10:39 AM
