Stock 83 LG4 Cam
Old Oct 19, 2004 | 03:56 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Stock 83 LG4 Cam
Does anybody out there in 3rd gen land know the specs or the part # of the cam used in 83 LG4?
Old Oct 19, 2004 | 04:11 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
https://www.thirdgen.org/newdesign/tech/techdb.shtml
14094097
Read em and weep
Old Oct 19, 2004 | 05:54 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Wow, that is tiny. So its the same as 1986 (LB9)
305 AT 14094097 .350 .385 178 194 109.0 (106/-112)
Aw :no:
Old Oct 19, 2004 | 06:12 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Yeah, amazing, eh? Makes you wonder why they let the engine rev to 4500 rpm. No power above 3000 rpm, just a lot of nothing ...
Old Oct 19, 2004 | 06:33 PM
Damon's Avatar
Like a Bugs Bunny cartoon when Bugs holds up a sign that says "Tiny, ain't it?" A little stock L-98 cam even looks like a monster next to the LG-4 cam.
Old Oct 19, 2004 | 08:31 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The LO3 cam is just as bad. .385/.381 on this beast.
Old Oct 20, 2004 | 06:57 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Those are both exhaust lobes you show yourself measuring in your pics.
But you're right, the L03 cam uses exactly the same profile as teh older LG4; it should measure about .266" on the lobe (that would be the difference between what you show the caliper on, and the measurement across the sides); which is .385". May measure a scosh lower than that exact # due to wear, of course. That was one of the factory's ultimate stupidities: they didn't seem to realize that they could improve their cam profiles by using rollers, instead they just copied over the same weak garbage from flat-tappet cores to roller cores.
Old Oct 20, 2004 | 09:00 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yup. I have a bunch of random pics and just selected 2 of them for clarity reasons. The other pics are sorta blury.
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
camaro71633
Sep 1, 2015 10:24 AM
