Wiper problem
Old May 22, 2001 | 08:09 PM
Eric L's Avatar
Wiper problem
i am having a problem with my wipers. it'll go up an inch and stop. do i need to replace the motor or what? it's supposed to rain for the rest of the next week and i need todrive my car!!!
Old May 23, 2001 | 12:16 AM
SCRA rules!'s Avatar
If these cars are like the 88-95 trucks, this is easy to fix. On the wiper motor assembly, the plug that the harness plugs into is soldiered to a little circuit board. Eventually, all these soldiered joints crack, leaving bad connections and wipers that don't work right or cut out at times. Just take the cover off the wiper motor assy, pop out the circuit board, and resoldier the connections for the plug. Takes all of 15 minutes.
'93 2wd truck
408 sb, vortecs, 454 TBI, Comp Cam, dual exhaust
Old May 23, 2001 | 11:40 AM
Steve89GTA's Avatar
Wow, I hope this fixes my problem, I've been suffering with intermittent - intermittent wipers for a while now! High and low speeds always work though...THANKS!
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
New Fuel Pump!
Autometer Vac+Oil Temp
2000 Yamaha R1 150hp 385ibs
Old May 23, 2001 | 08:22 PM
Eric L's Avatar
mine doesn't have the circut board in it
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
Glowsock
Sep 6, 2015 06:40 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
