What head gasket for E-Tec 170s and 11:1 compression?
Old Oct 20, 2004 | 04:27 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I have a 350 with flat top pistons and I will be putting on Edelbrock Etec 170 heads this weekend. I would like the compression to be 11:1 and the only way i can get it there is to use a steel shim head gasket .018-.020 thickness. How well would these seal aluminum heads to my block? Should I just go with GM's composite ones (.029 thick)?
Old Oct 21, 2004 | 09:47 PM
GASGZLR's Avatar
Well the instructions don't say anything about putting shim gaskets on but they do recomend the GM .028 ones, I guess I will go with those.
Old Oct 21, 2004 | 11:42 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Yes... I believe the part # is 10105117
Do not use shim gasket on alum.
Old Oct 22, 2004 | 04:18 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Look into Felpro 1094 gaskets for the alum. heads.
Old Oct 23, 2004 | 09:20 AM
peter315's Avatar
clearance
if you go to a thinner head gasket you will be loosing piston to head clearance. it really needs to be .035 or more for safty. also going down even .020" will only remove 4cc's.it might get you to 11-1 if all other dementions are really tight. so you will end up with an engine that will probably need 94 octane minimum and the pistons may hit the heads. if however your deck hieght has the pistons .025" down the bore, which is standard on 350 chevy you won't have a clearance problem, you won't get near 11-1 compression, and the steel shim gasket will ruin your aluminum heads. there are however coated gaskets in the .025" range available for this purpose that may help.
3rd gen money
Sep 8, 2015 11:40 PM
NinjaNife
Aug 23, 2015 11:49 AM
Dialed_In
Aug 20, 2015 01:45 PM
NWAsonoma
Aug 18, 2015 05:45 PM
