Oil Cooler - Do I need it?
Old May 22, 2001 | 10:03 PM
CamaroX84's Avatar
89 5.7 L TPI motor, came with an engine oil cooler. Will I have problems if I don't run it? Thanks.
Old May 22, 2001 | 10:08 PM
LottaBallsCamaro's Avatar
You probabaly wont have problems except your engine wont live as long...I have to ask why you want to delete it...they were put there for a reason...
Old May 22, 2001 | 10:09 PM
Old May 22, 2001 | 10:21 PM
CamaroX84's Avatar
It's just that the tubes for it are real messed up, and I don't want to mess with it right now. I could add it later I suppose. Thanks.
Old May 22, 2001 | 10:24 PM
SUPER-SPORT-CHEVY's Avatar
No you wont have problems. The only down falls I se eare your engine life will probably decrese but nothing you will ever notice. The other problem is your oil temp will rise a bit higher and it could decrease oil life. I would rather have one than not though.
SSC
Old May 22, 2001 | 11:20 PM
Guest
Guest
Posts: n/a
The factory oil cooler is a joke. You wont have any problems running your engine without it.
Old May 23, 2001 | 08:19 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Yep, not necessary to have one at all. And as long as you run synthetic oil, the warmer oil will make more hp and engine life would probably be increased.
Old May 23, 2001 | 10:45 AM
KeithO's Avatar
I'm pretty sure that the following is accurate:
At some point in time, the standard Vette LT1 engine ceased to have an oil cooler because Chevy begain requiring synthetic oil. There was a time of overlap where there was an oil cooler and the synthetic requirement. Then, Chevy was comfortable with eliminating the cooler with what they learned and now require synthetic oil is used.
I'm reasonably sure that this is true. Even so, I'm personally more comfortable leaving the oil cooler equipment intact on my L98. It was designed believing that it was to be used...
Old May 23, 2001 | 11:16 PM
Guest
Guest
Posts: n/a
Do the LT1's in the F-bodies have oil coolers?
I know my dads 1 ton work van doesnt... I would think if they were worried about it, a one ton van would have one stock.
Old May 24, 2001 | 01:30 AM
89ROC's Avatar
<font face="Verdana, Arial" size="2">Originally posted by madmax:
</font>
Some do, some don't. I'm assuming it was optional...or something like that. Mine doesn't have one. The oil coolers that come with the LT1 f-bodies are useless IMHO. They just run hot coolant thru the adaptor on the engine block. I don't see how that can actually cool the oil enough to make a difference.
Old May 24, 2001 | 01:34 AM
Guest
Guest
Posts: n/a
Thats exactly the same thing thats on the thirdgens. Its too small and has too little contact with the oil to do anything IMO.
tyeo098
Nov 30, 2015 06:27 PM
1992Z28!
Nov 19, 2015 07:33 AM
skinny z
Oct 5, 2015 06:23 PM
CatmanFS
Sep 19, 2015 09:00 AM
apie2546
Sep 5, 2015 07:40 PM
