an eeeee sound
Old Oct 24, 2004 | 11:12 PM
ralpax's Avatar
an eeeee sound
hello all,
i have a 89 camaro rs v6 and i have a few questions.
1) Most of the times i push in the gas peddle i get this quite eee high pitch sound that kinda sounds like something a electronic would give off, what is it?
2) should the trunk be able to wable alot if you pull up? it doesnt open it just isnt very tightly closed.
thank you
Old Oct 24, 2004 | 11:23 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Well as far as the trunk thing goes.....its probably just the latch is out of adjustment. My Camaro's trunk latch didnt close very well and one time it even flooded out because it didnt latch right...ruined a lot of **** I had laying in there!
As far as the eeee noise....you're probably going to have to be a lot more specific. Like, where does the noise sound like it's coming from....is your performance affected at all... Maybe a bad pulley bearing, or a PS pump low on fluid or going bad? Or maybe a bad wheel bearing? Or maybe your brakes are dragging and squealing?
Old Oct 24, 2004 | 11:26 PM
ralpax's Avatar
its a relaly high pitch sound so its hard to really tell..i think maybe from the dash on the driver side. it doesnt affect anything i just am a bit worried about it. It only happens if i psuh on the pedal and it doesnt do it everytime. could it be that when i push on the gas peddle it hits some wire that makes oen of the speakers make it?
Old Oct 25, 2004 | 12:31 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Sounds like without actually hearing it that it could be the speedo cable. They need to be lubed every couple of years. You can get cable lube at a autoparts store.
Old Oct 25, 2004 | 07:42 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
If it is an '89, then you have the automatic pulldown on the rear hatch... it is probably broken and needs repair (visit TDS, a sponsor of TGO for repair kits).
Old Oct 25, 2004 | 10:29 AM
ralpax's Avatar
i hope that is that. I read somewhere that if your spedometer goes up and down alot when it should be steady that it should be lubed and thats what happens to me. thanks for all the help
Old Oct 25, 2004 | 12:56 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Yep.
Old Oct 25, 2004 | 09:26 PM
ralpax's Avatar
ok..the sound only happens when im driving so its very possible its coming from the cable but it doesnt get louder if i go faster or quiter if im going a constant speed so i dont know if its that. Could it be a belt thing? oh and i just found out that i have two small holes in my radiator that just got bigger today and drained all my fluid...could that of been it?
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
