Unsual head casting? Anyone know?
Old Oct 25, 2004 | 03:00 PM
mavis_1's Avatar
Car: 89 iroc convertible
Engine: 305 tpi
I went to a swap meet this weekend. While there a friend decided to buy a set of unmatched bare heads based on their casting number. The first head was a 993 casting. 993 appeared on both the bottom of the intake / exhaust runner and the rocker valley. The second head however had a 487x on the runner bottom and a number that ended in 993 just like the previous head. Does anyone know what is up with that? I tried the net but everything I found says that both runner and rocker valley numbers should match. Thanks Guys.
Old Oct 25, 2004 | 03:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like somebody pulled the old "spec" circle-track trick, of taking a better head than the "spec" and grinding off and replacing the number with the one for the inferior head the "spec" calls for.
So, it's one 993 casting, and one mutilated 487X casting. Not a set at all.
Old Oct 25, 2004 | 06:17 PM
LG4TA's Avatar
Car: 83 T/A WS-6
Engine: LG4 305
Transmission: T-5 Manual Clutch
Axle/Gears: 3.73 Positraction
487X
Both heads are supposed to be 75 cc's though. You could have different size valves though.
Old Oct 25, 2004 | 09:21 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
How do you do that? You got me now, i'm interested in how though! I can see grinding off the numbers, but how do you put new ones one. Casting?
Old Oct 25, 2004 | 09:25 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
epoxy
Old Oct 25, 2004 | 09:30 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Duh!
Old Oct 25, 2004 | 10:27 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Amazing what you can do with a little JB weld.
Old Oct 25, 2004 | 10:57 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Yeah i was like, man these guys want to win, casting new iron numbers. :lala:
Old Oct 27, 2004 | 09:21 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
http://www.castheads.com/
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
