Simple Spark Plug Wire Question
Old Oct 27, 2004 | 04:51 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
When I put my headers on I put a set of those accel 8mm supression core spark plug wires on (the basic yellow ones). I got the ones intended for the LO3 problem is they have striaghts that eventually burned on the headers. What would you guys recommend for a 90º spark plug wire set under $40?
Old Oct 27, 2004 | 04:53 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Taylor, MSD, mallory, and moroso all make universal 90* boot sets for around 50 bucks or so.
Old Oct 27, 2004 | 07:03 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
accel also makes a set with 90 degree boots. Not as good as teh others but theyll work.
Old Oct 27, 2004 | 07:27 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I ran 8mm taylor wires for 2 yrs on my 355 and liked the things...only gripe is the boot is too dam big. It's nice for helping thwart off arching issues, but with my old Heddman LT headers I had a few boots that had no choice but to hit the header tube-they're that fat.
other than that they worked really good. I like my current 8.8mm MSD's, but they're $90
Old Oct 27, 2004 | 09:04 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
If you're looking for a pre cut set that works with headers that have pipes that all go downward, the MSD truck type for late 80s full size sbc works just right.
They have 90deg boots and the factory routing is around the rear of the valve covers and then follows the valve covers along the side.
Old Oct 28, 2004 | 09:32 PM
Car: 91 Camaro RS
Beside Accel, will I be able to get any of these locally though ordering at a parts place?
Old Oct 28, 2004 | 09:47 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Autozone sells various MSD stuff. You could also order them online and have them sent to your front door.
Old Oct 28, 2004 | 09:56 PM
91RockS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI (L03)
Axle/Gears: 3.73 Truetrac posi
I just put a set of the accel 300+ 8.8mm wires on my L03 that I am real happy with. They have very low resistance and can take +500F temp. I first bought the custom fit style, but two of the plug boots had straights. With my headers, I need all 90's. Returned them for the Universal fit style with all 90's. The spark plug ends come already crimped on, but you have to crimp on the distributor end terminals, which turned out to be real easy. In the end I was glad I went this route since I was able to perfectly fit each wire with no extra length to deal with. Price was about $65.
Old Oct 29, 2004 | 03:20 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
those work great. that's what i've been using.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
djmarch
Aug 9, 2015 05:27 PM
