Can't get the lid off
Old Oct 29, 2004 | 08:25 AM
RachaelRider16's Avatar
Car: 1989 Camaro RS
Engine: 5.0 ltr. 305 TBI stock with holes d
Transmission: T-5 five speed
Why is it that when I need to put oil in my car, I need He-man to turn the cap? I mean I always tighten to one click, but still it's like someone welded the stupid thing on there. What's goin' on with that? 'Cause I really need to put some oil in there. Thanks.
Old Oct 29, 2004 | 07:35 PM
CaysE's Avatar
Oil caps don't click. They just turn half way or so and "lock." If it's getting stuck, the cap is probably wrong (especially if it clicks like a gas cap), or there's crud on the cap or valve cover where it locks into place. I would think about getting the oil system cleaned and flushed if that's the case.
Old Oct 29, 2004 | 09:28 PM
Morley's Avatar
Re: Can't get the lid off
Expansion and contraction from heating and cooling make it tighten up...all I can suggest is: go to the gym and work on your forearms
1 click after it bottoms out is correct ,BTW, just like your gas cap.
Old Oct 30, 2004 | 01:24 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Huh? Oil caps should just twist 1/2 way and stop... Don't want to sound like an ***, but you are talking about one in the valve cover right?
Old Oct 30, 2004 | 07:59 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
The later model cars do have a cap that clicks after it bottoms out.... like a gas cap.
Old Oct 30, 2004 | 01:34 PM
Air_Adam's Avatar
Oh... had no idea
I'd suggest getting the cap off, and soaking it over night in some kinda cleaner or degreaser. See if that helps.
Old Oct 30, 2004 | 01:46 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I was about to chime in but it was already said. My car has the clicker to. Seems like it is usually pretty hard to get off.
Old Oct 30, 2004 | 05:56 PM
sellmanb's Avatar
Car: '86 Berlinetta
I dont know about your guys' oil cap shape, but mine has about 5 "grooves" where I can put a flathead screwdriver and just give it a good whack once with a rubber mallet.
Old Oct 30, 2004 | 06:41 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
i would have you call you wife to get it off for ya, ya know they open those jars all day
my car and truck both get that way it must be the heat and cooling that tightens em. i don;t know of any fix for it.
Old Oct 30, 2004 | 08:21 PM
Vader's Avatar
The next time "He-Man" gets the cap off for you, clean both the cap and the adapter on the rocker cover that the cap screws into. DO NOT use any sort of degreaser, just a dry paper towel and soap if necessary. Once the cap is clean, apply a thin coating of clean engine oil, or better still, silicone grease to the 'O' ring on the underside of the cap. The 'O' ring is what is binding.
Don't so the "Wonder Woman" thing when installing the cap. One click is more than sufficient, and possibly too much. Just turn it until it is snug and leave it alone.
Old Oct 31, 2004 | 01:55 PM
Car: 1989 Camaro RS
Cool. Thanks for all the input.
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
gta power
Convertibles
Sep 23, 2015 09:32 AM
chuck13
Sep 22, 2015 11:19 AM
SG91camaro
Sep 5, 2015 10:27 PM
mav75
Aug 31, 2015 12:16 AM
