car wants to start just some times
Old Oct 29, 2004 | 10:18 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Well this is some what similar to the problem I had with my 305 that my car would sometimes not start when hot or just not start at all, and then would have to beat on the starter with a tire iron. But now I have a new engine (350 TPI), new alt. from the 305 (about 5 months of use), a newer starter that I got with the new engine, and an optima red top. The problem is it does not start some times when hot, but most of all I have to try a few times even when cold. When I try to start it when cold you can here the starter ingage and then disingage ( sounds like a tick- toc noise). What can this mean? So I am thinking that it might be the starter since it has a little trouble to start to begin with. So I am not really sure what to do here. And this keeps me from driving some where far when I know my car will not sit for a long time.
Thanks in advance
Kevin
Old Oct 29, 2004 | 10:59 AM
ede's Avatar
ede
bet you don't have a "new" starter. try getting a new, or bigger (actually smaller size) and i bet your problem goes away. you might want to make sure all the connections are clean but i bet that isn't the problem.
Old Oct 29, 2004 | 11:14 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Yes, get a mini-starter, and make sure you have very good terminal connections. Also make sure you have a large ground wire directly from the N- battery terminal to the engine block.
The problem is the starter and solenoid get heat soaked and their resistance goes incredibly high.
Old Oct 29, 2004 | 06:40 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
i had the same problem after tranny install. i removed converter cover and coil wire and watched starter while wife turned key. the gear was hitting the flexplate about half the time. bought some starter shims and after a lot of trying finally found the right combo. look to see if it is this before going through all the wiring.
Old Oct 29, 2004 | 08:51 PM
Engine: L98 350 TPI
Well I did buy a Mini starter about a year and a half ago, but the jerk who I bought it off on Ebay swrewed me out of $80. It just seems now matter what it is with my cars the starters or the starting process is messed up.
BTW thank you everyone for you imput.
Kevin
Old Oct 30, 2004 | 12:37 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Get the motor tested at a autoparts shop or dealer (autozone, SCK...). I still bet its your connections.
Old Oct 30, 2004 | 01:10 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
goto http://www.turbobuicks.com get the mini starter, i just got mine solved all my problems with starting and sitting in parking lots asking for jump starts 125.00 shipped with bolts.
Old Oct 31, 2004 | 04:00 PM
hoogabooga's Avatar
Engine: 427 454
Transmission: TH400
https://www.thirdgen.org/techbb2/sho...07#post2056707
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
86Base
Aug 8, 2015 01:34 PM
