Car Takes Forever to get into closed loop.
Old May 27, 2001 | 04:36 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
if the engine is at 210 degrees and I start the car it'll take a good 5-8 minutes for it to go into closed loop even when its that hot. Any ideas?
Old May 27, 2001 | 04:47 PM
Vader's Avatar
Mkos,
If you are using headers you might have a cold O2 sensor. The oxygen sensor must get hot enough to start reporting a varying voltage to the ECM before closed-loop can happen.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old May 27, 2001 | 04:51 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I am using headers, but this all happened right after intake swap. I'm thinking(since you've read my other posts) that the CTS may be screwed up because of the bogging problem with cold and the Closed loop and other varies things.
Old May 27, 2001 | 06:18 PM
IROC5.7TPI's Avatar
Too cold of a thermostat
Mike L.
1987 IROC Z TPI 350 A4 3.27 Borg-Warner.
Mods: 2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified Airbox w/ K&N's, Relocated MAT sensor, Gutted MAF, Accel 8mm Wires, bypassed TB coolant, Flowmaster 3 chamber single 3" in/out muffler, airfoil, Random Tech Hi-Flow Converter (soon to go byebye!). ALL STOCK otherwise.
http://www.MichaelLasiuta.home.att.net
**BOYCOTT LAPEER DRAGWAY**
Azrael91966669
25
Jun 20, 2017 04:04 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
jharrison5
Aug 19, 2015 05:53 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
