Car won't start? HELP!
Old Nov 1, 2004 | 03:46 PM
89Firebird Formula350's Avatar
I have an 89 Firebird Formula 350 TPI Auto. This happend to me once before. When I put the key in the ignition and turned it to start it, all the gauges lit up, radio came on, gauges worked, temp went up, but it didn't start. It was just just silent, no clicking or anything when turning the key. What could this be? I already replaced the started and solenoids and it still doesn't work. Any suggestions would be great! Thanks!
Old Nov 1, 2004 | 03:52 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
i had that problem and after checking everything else i found it was just a loose connection in steering column. if you have tilt steering wheel try lowering it all the way then turn key. that would get mine started until i could fix.
Old Nov 1, 2004 | 07:22 PM
black90rs's Avatar
Car: 82,84,90
Engine: camaros
i got a 91 rs and mines doing the same thing.. Im bout to go check the ignition switch and the starter relay.. if i find anything ill let you know
Old Nov 2, 2004 | 12:31 AM
Hey thanks a lot man! Let me know when if you find out! I'm going to keep trying myself as well. Let me know!
Old Nov 2, 2004 | 01:02 AM
sellmanb's Avatar
Car: '86 Berlinetta
1 word -- ground
check the ground at your steering column (this one controls your ignition for your key, and if no ground then it wont work... like the person who had the tilt steering column problem... he'd have to lower the column to get the ground to touch).
check the ground at your starter
check the ground on the block (it's the smog pump for LG4's atleast, not sure bout serpentine one.... just follow the negative cable to the block and chassis).
Check those and if it still doesnt work then look at fusable links.
Old Nov 3, 2004 | 03:45 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
VATS
Old Nov 3, 2004 | 03:48 AM
black90rs's Avatar
Car: 82,84,90
Engine: camaros
yeah check the vats... forgot to mention that.. but mines fine as the security light comes on for 2-3 sec. then goes off... i havn't even got to work on my car since it raining all the damn time so i will let you know once i find anything out
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
