Why's my car shakin?!??
Ok check this stuff out....It's in my 4th gen...but i figure there isn't much difference...I can be driving..then all the sudden my whole car shakes violently, steering wheel majorly...i thought i had a flat tire! i got out and checked and they were all good...this happens when i get over about 50 mph...but then it goes away after a few minutes of shaking....i thought it might be the tranny, so i put it in neutral, and it still keeps shaking!!! So I have about pinpointed it to the wheels or tires or suspension correct? Maybe a wheel bearing???
Help me out guys...This is my daily driver!!
1989 307 RS, soon to be 350.
1995 Red T-Top Camaro, 3.73 gear, F.I.P.K. K&N,Flomaster Cat-Back, Gutted Cat...Killer Stereo (Cerwin Vega and Sony Xplode)
sounds like a suspension/wheel problem. does turning have any effect on it? i would jack the front end up and take a look at the tie rod ends and ball joints.
85 IROC 350 11:1keith blacks,.555lift erson roller cam,1.5 crane roller rockers,edelbrock intake,holley 4150 750dbl pumper, nitrous oxide,full length heddman headers,true dual exhaust, 11"stall converter, 700R4, 3.73 locker
Check and make sure your tires don't have any bulges in them. Even small ones will do it (and from the sound of it, it may just be a small one)
When was the last time you had your tires balanced? Drive through mud lately? (remember my cousin Vinnie?) The mud sticks to your tire and dries... and causes it to be unbalanced...
Check around on all the suspention stuff down there, make sure everything is tight (not hanging off).
If it's nothing you can pick out with your own eyes... take it to a trusted tire/suspention place in your area and have them check it out...
Drive CAREFULLY!
And good luck.
1985 Camaro SC - 2.8L, auto.
Mods:
Removed air baffles, mandrel bent cat-back pipes (but stock replacment muffler, Dynomax Turbo and Catco converter are on thier way)
Drive CAREFULLY!
And good luck.
Mods:
Perhaps the driveshaft?,i agree about the tires,if she sat all winter then the wheels can get flat spots.
www.rearman.com/camarokid.htm
If it aint a V-8 that $hit aint fast!,unless its a GN,lol!
305 tpi,700r-4 with shift kit,My mods are minimal,just a bunch of little $hit.Anyone know where to get underdrive pulleys for a v-belt set up?
Had the wheels aligned lately? The exact same thing happened to me, and i got all these different prognosisesses on what was wrong, but all i needed was an alignment. Now i can go well over 100 and not have any wobble or anything. Well *cough cough* thats in theory... :P
Tom
93 Saturn SL2- Daily driver
73 mustang- 250 6 and 3 speed tranny -lookin for a 5 speed, anyone got one??
72 firebird formula- a weekend warrior in the making-- that is if I ever get the engine together and in the car
Tom
Car: 2006 Silverado 1500
Engine: 5.3L
got a 94 myself and haven't run into that on mine or at work, but i'd guess from the description that you have a problem from the driveshaft. i do see you said it is harsh from the steering wheel which means you should check the tie rod ends and ball joints.
ok well i don't think it's out of alignment, because i got a ticket for 96 the friday and this started on wednesday....I was thinking main bearing where the driveshaft goes into the transmission the more i've thought about it...because it's not a constant thing, and it is hard to put in gear and i get a kind of humming sound when i let off the clutch til it warms up....Any ideas now?
It's a T-5
Car: 91 Z/28 convertible
drive your car down the road and note the rpms when the car starts wobbling now stop your car and drive your car to the same rpms but in first gear if it wobbles in first at the same rpms then its your drive shaft if it doesnt wobble in first at the same rpms then you now know for sure it isnt your driveshaft
<A HREF="http://www.geocities.com/thirdgenerationcamaro
89" TARGET=_blank>www.geocities.com/thirdgenerationcamaro
89</A> camaro
carburated 305
bored .030 over
flat top pistons
bigger valves
heads and block shaved
spoiler
tinted windowshuge white chevy symbol on back
92 stock rims
92 ground effects
89</A> camaro
carburated 305
bored .030 over
flat top pistons
bigger valves
spoiler
92 stock rims
92 ground effects
it does it when the car is out of gear and in neutral...or when i have the clutch pushed in....but it only does it maybe once or twice on my 30 minute way to work and on the way back.....what is this???
uhhh... What does the road look like?
Just kidding, I don't got a clue. My third-gen shakes pretty bad when I hit the brakes, but I just had the rotors machined by a reputable shop! Ah well, sh(t happens.
305 TBI, 700r4, 2.73 peg-leg...WS6 is good, though
14X3 o.e., functional formula hood(for sale in future), uhhh..., umm...
Soon to be dual TBI, heh, heh, heh
Am I the only person who believes a car has feelings, emotions, and a soul??
if it constantly happens at high speeds, get your tires rebalanced. It will only take a small pothole or brush against a curb to knock these things out of balance. Check to see if your missing any wheel weights also. Start with the simple stuff.
85 Berlinetta Iroc exterior NOW 454 powered, 4.10 gears, 275/60/15 Hoosier Quicktimes and a PILE of other goodies..........YES, it's street driven!
check it out at http://www.bsronline.net/members/rob/rob_specs.html
Linson
Aug 21, 2015 02:12 PM
