Stall converters
Old Nov 1, 2004 | 10:57 PM
Duke901's Avatar
Car: 89 Formula
Stall converters
What company would you guys recommend.
Thanks Mike
Old Nov 1, 2004 | 11:03 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I'll be in the market for a new TC in the next few months.
I've heard very good things about Vigilante, Yank, and TCI. Vigilante is the best, but at $730 each, it better be. Yank seems to be a bit cheaper, around $450-500 I believe, and TCI seems to be around $250-350 if I remember right.
I was planning on a Vigilante 3000-3200, but I don't know if I'm going to be able to spend $730 on a new torque converter. I may go cheap and pick up a TCI, unless I find a Yank or Vig for sale used, etc.
Old Nov 1, 2004 | 11:08 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
ive said it before and ill say it again ..get a B&M and be done alot less money and ive never seen any problems out of them ...used them myself along with many others i know....
Old Nov 1, 2004 | 11:30 PM
Car: 1997 Corvette
Are Jeg's converters any good? I like the sound of their 9" converters with lock-up for $450.. I know that I want a lock-up converter, preferably 9"..
TCI has a nice-looking 10" lockup converter with a 3000 stall (Streetfighter) for around $450ish as well..
Old Nov 1, 2004 | 11:57 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Here is why I plan on getting a PI Vigilante when I finally get my new TC...
Some great articles on the Precision Industries site:
http://www.converter.com/truth_prices.htm
http://www.converter.com/truth_warranty.htm
http://www.converter.com/torqueratio.htm
These should be required reading before buying a converter.
These are good too:
http://www.converter.com/whatsnew_dynamometer.htm
http://www.converter.com/whatsnew.htm
Remember you get what you pay for a lot of times... PI manufactures their own backing plates and front plates instead of reusing stockers like MOST companies do...
IMO... w/ a transmission, you are asking for trouble if you don't get a Yank or Vigilante... But that is just my $.02...
Old Nov 2, 2004 | 12:48 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
What have you done to the 305 to warrant a 3k to 3200k Trq converter? With too much stall your converter will just keep spinning and transfer heat to your tranny which is not good. Makes for a short tranny life.
Old Nov 2, 2004 | 01:04 AM
Car: 1997 Corvette
Ported LT1 heads, LT1 intake, a cam somewhere between 208/218 and 222/232 duration, 1 5/8" headers, and 3.42-3.73 rear gears.
I'm going to get all of that set to see how it drives before I get a converter, but I'm guessing I'll need close to a 3000 stall...
Old Nov 2, 2004 | 01:27 AM
OK...just wondering. Too many people get way too much stall for their application. Here's a couple articles to help you figure out which one you may need. http://www.hardtail.com/techtips/torqueconverters.html
http://www.hardtail.com/techtips/sel...converter.html
Enjoy
Old Nov 2, 2004 | 06:12 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Vig and Yank of the same stall speeds are priced similarly. I run a Vig 2800 in my 95 Z28 and a Yank ST3500 in my IROC, and I love them both.
Also check the classifieds at camaroz28.com. I see Vigs for sale quite a bit over there so you might get lucky.
Is your 700R4 a 30 spline?? If so, you can use a TC made for 93-97 LT1 F bodys...which is why I suggested looking at the classifieds at cz28.com.
Old Nov 2, 2004 | 06:50 AM
Car: 1997 Corvette
Mine is. Yeah, actually I realized the converters are a bit more than I had thought (the "good" TCI ones tend to be upwards of $450, while the cheaper closer-to-stock-replacement ones are $250-350).
Yeah I have seen some Vig's for sale there for $500ish.
Old Dec 8, 2004 | 07:52 AM
laiky's Avatar
i'm lookink into edge converters for a new probuilt 700. Probuilt reccomends edge and vigilante. Anybody have experience with edge?
Old Dec 8, 2004 | 09:15 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
"That means that a car producing approximately 300 ft/lbs. of torque at the flywheel will put out approximately 600 ft/lbs. of torque at the rear wheels (less any parasitic losses from mechanical drag and the operation of the converter itself)."
Old Dec 8, 2004 | 10:06 AM
laiky's Avatar
you forgot the account for the gearing of the tranny
Old Dec 8, 2004 | 10:14 AM
Where did that quote come from? Was it from an article i posted a link too?
Old Dec 8, 2004 | 10:24 AM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
I was very happy with my ******* Performance converter...
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Great for the price!!
Old Dec 8, 2004 | 10:50 AM
Car: 1988 IROC-Z
Engine: 427 SBC
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
amcnellis
Sep 16, 2015 04:16 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
