car smokin
Old Nov 2, 2004 | 12:13 PM
Berlinetta's Avatar
car smokin
alright, just put some new heads on the car but it smokes now where it didn't before. Heads were warped, so they were replaced but now the car smokes. After i got the heads on, it started right up but it looked like cheech and chong going down the road. But now, it wont smoke until it warms up a little bit. It's fine for about a minute or two, then it starts up smoking. It doesn't smoke near the amount it did when i first got the heads back on and started it... WTF?
Old Nov 2, 2004 | 12:17 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What color smoke.
Old Nov 2, 2004 | 12:19 PM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
Is it smoke or steam? If it's steam you need a head gasket.
Old Nov 2, 2004 | 12:24 PM
ljnowell's Avatar
definatly need to know the color
Black = fuel
Blue = oil
White= steam, water burning.
If its white, before you drive it any more, check your oil.
Old Nov 2, 2004 | 01:22 PM
Berlinetta's Avatar
forgot to mention color... its white. Since when was burning oil blue? i thought it was white. I let it run for 30 minutes and had to put more oil in it. It lost about half a quart while it ran. Ive run it since then and it still loses oil, but more slowyl.
Old Nov 2, 2004 | 01:28 PM
Engine: 5.7, 5.0
What color is your oil? does it look like a milkshake, foamy and light brown in color.
BTW. If your burning oil it's a white/blueish color. Fuel is black. If it's white billowy smoke, like yours seems to be, it's steam and you need a new head gasket.
Old Nov 2, 2004 | 01:39 PM
Berlinetta's Avatar
no, the oil looks like oil... the head gasket is new
Old Nov 2, 2004 | 01:49 PM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
where the heads torqued down correctly?
Old Nov 2, 2004 | 01:53 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Just because its new doesn't mean it was installed properly.
Check your coolant as well to see if oil mixed in since you said its using oil as well.
ljnowell's Avatar
blue is definately oil. White is steam, or burning coolant. Check your coolant and feel for oil. My guess is, if the oil looks OK, but you are blowing white smoke and loosing oil. You have oil in the water. You are probably getting some water in the oil too, you just havent been able to notice it yet.
Old Jan 2, 2005 | 02:39 PM
rolling-robert's Avatar
Car: z-28 x2
Engine: 355ci and 305ci
Transmission: th350 and th350
Ooh my ***, that sounds just like my new engine is doing, some oil floating on the coolant, and white smoke from both my exhausts!!!
damn!!!!
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
