vibration
Old Nov 2, 2004 | 07:38 PM
1986lt1boy's Avatar
Car: 1986 Trans AM
Engine: 396 LT1 Stroker
Axle/Gears: Ford 9 Inch w/ 3:70 Gears
vibration
Hey guys i have a problem with my TA. Its a 1986 Trans AM. I have a 94 LT1,4l60e trans and 9 inch rear. When im driving around and the car is in 3rd gear and i step on the gas. The car makes a clunk sounds like something is banging but there are no marks under the car and the tranny mount isnt ripped. Also when the car revs past 4500 rpm there is a horrible vibration in the car until it shifts gears. I have had the driveshaft and tires balanced, no difference. I think it might be caused due to a driveshaft angle misalignment. Has anyone had anything like this happen to them? Or does anyone know of a driveline specalist that might be able to fix this problem?
Tom
Old Nov 2, 2004 | 07:45 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
Maybe one of the motor mounts are ripped?
Old Nov 3, 2004 | 03:34 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
does it vibrate just reving, or only when the vehicle is in motion, if it vibrates while sitting still and reving the engine, the problem is in the engine.
Old Nov 3, 2004 | 11:19 AM
1986lt1boy's Avatar
Car: 1986 Trans AM
Hey quickstyle, thanks for the reply, no it only happens when the car is in drive in every gear while im driving.but if i shift it to neutrel while im driving it goes away.
Tom
Old Nov 3, 2004 | 10:07 PM
QuickStyle's Avatar
Car: 91 Z28
its definatly somewhere between the flywheel, and transmission, seeing as it stops vibrating when the engine is disconnected from the transmission. also, is it an auto or manuel.
Old Nov 3, 2004 | 10:16 PM
1986lt1boy's Avatar
Car: 1986 Trans AM
Its a 1994 auto 4l60e trans.
Tom
Old Nov 3, 2004 | 11:41 PM
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
I'm no expert, but maybe it has something to do with your driveshaft being out of balance. It could be the cause, especially at higher engine speeds. Other than that, tranny problem maybe?
Old Nov 3, 2004 | 11:46 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
could be driveshaft out of alignment also could be driveline angle out of adjustment .....
Old Nov 4, 2004 | 01:10 AM
QuickStyle's Avatar
Car: 91 Z28
he said it wont vibrate when its in nuetral, which makes the driveshaft still spinning, which makes it related to the front of the transmission or TC or flexplate
Old Nov 4, 2004 | 01:42 AM
305RSlc's Avatar
Uh, does the driveshaft spin in neutral? The last time I checked the car does not move when it's in neutral and I"m pretty sure that the rear end is not the thing that prevents it from moving.
Old Nov 4, 2004 | 03:40 AM
QuickStyle's Avatar
Car: 91 Z28
when the car is in motion, lets say 80mph, you put it in nuetral and coast down the road at 80mph, yes the drive shaft still moves, as it is connected to the rear end, and the rear end is in motion.
Old Nov 4, 2004 | 05:28 AM
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
What does the tranny crossmember look like?
I know in my 82, mine looked like this, and the bushing between the two halves on the driver's side had broken and was completely gone, and I had the same problem. The transmission was turning and thumping the top half against the bottom half.
As soon as i put it into neutral, it would stop
File Type: bmp
Old Nov 4, 2004 | 11:25 AM
1986lt1boy's Avatar
Car: 1986 Trans AM
the tranny crossmember in there now is a spohn custom made piece. I had his torque arm too. IT was made wrong and it was a piece of crap, i think he messed up when he made the crossmember too because i think that it is the problem. I think that the angle on it is wrong. I am going to put my stock tranny cross memebr back in and stock torque arm this weekend and see if the vibe goes away. If it does then i know the crossmemebers tranny mounting angle is off and its causing the vibration, if it doesnt go away then im guessing i have a problem with my tranny or rear end. but I dont think so because they are both new less than 10,000 miles on them.
Old Nov 4, 2004 | 12:18 PM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
One thing that no one ever seems to remember is that the driveshaft angle has to be correct in a Horizontal plane as well as a Vertical plane.
When you remove a transmission crossmember you should make a mark it's position so that it goes back in EXACTLY the same position. During a clutch swap, we were not carefull enough with this. The crossmember was out only 3\8" from it's original horizontal position, but that was enough to cause a HUGE driveline vibration. Loosenning the bolts and realigning the crossmember solved the problem in about 5 minutes.
If you change crossmember types, mark a couple of reference points on the chassis before removing things. Take a measurement from these points to the driveshaft to make sure that you can get the driveshaft back to it's correct position in a Horizontal plane.
Bit late now....but can you take some measurements off of a friends car to establish a baseline? ( One that does not vibrate hopefully LOL )
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
