Donut Gasket Continually Blows
Old Nov 3, 2004 | 05:55 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
Ok guys today i went through my 3rd passenger side donut gasket. Teh damn thing keeps melting and they end up blowing to bits.
I was driving and all the sudden "wow pam" and the car is loud again.
Bought the part for $12, made out of ceramic this time.
But why is it doing this guys?
update: No A.I.R system no cat, and the freeest flowing cat back ever designed. So.... iunno. I have no fange gaskets but they are on there tight so i have no clue.
Also, it does seem to come out when i'm on rough roads....
shane
Old Nov 3, 2004 | 05:58 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
wooops mods please move to exhaust
Old Nov 3, 2004 | 07:38 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Are you sure your exhaust system need donuts? I know your exhaust is modified. Maybe you really need some flat collector flange gaskets?
(BTW - I know that kinda sounds like me being an ***, but I don't )
Old Nov 3, 2004 | 08:06 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Yeah what is this donut gasket you speak of? At what connection is the gasket failing? What part is it, brand?
Old Nov 3, 2004 | 08:18 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
the edelbrock headers were meant to be exactly like stock excepot for being headers, you can even bolt them to the stock y-pipe if your dumb enough. They are pretty much like stock.
this time i got a nice felpro donut gasket.
Old Nov 3, 2004 | 08:22 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Your not supposed to use gaskets on those connections, its supposed to metal to metal.
Old Nov 3, 2004 | 08:23 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Old Nov 3, 2004 | 08:41 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
well this one particularly needs a gasket, cause if i dont use one it leaks like a biatch.
Old Nov 3, 2004 | 08:42 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Its not supposed to, now you know why somebody sold them to you.
Old Nov 3, 2004 | 08:44 PM
THEGENERAL's Avatar
if your going to use a gasket at all you should only use a flat gasket not a donut gasket ....
Old Nov 3, 2004 | 08:46 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
they are meant to use donut gaskets dummy. Thats why they are in the manual to every muffler shop i went to to find the damn things.
Please dont dawg up on my guys, i'm not fn stupid.
Old Nov 3, 2004 | 08:47 PM
THEGENERAL's Avatar
watch out on the name calling there big guy its not needed and a total violation of thirdgen.org rules....
Old Nov 3, 2004 | 08:57 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Now i know why edelbrock headers are crap, they do require a donut gasket. The stock connection do not have gaskets, they are metal to metal. So its leaking where the header connects to the y-pipe? What y-pipe are you using?
Metal donut gaskets
Old Nov 3, 2004 | 09:00 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
thanks for the link man, those arn't exactly what i need, but i found it somewhere else just incase this one melts also. So.... iunno...
but yeah they do require donut gaskets.
Old Nov 3, 2004 | 09:02 PM
THEGENERAL's Avatar
maybe you ought to look into a better set of headers ?...
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
i already am bro, i already am, looking for long tubes.
which ones would you reccomend?
Old Nov 3, 2004 | 09:04 PM
THEGENERAL's Avatar
i dont really car for long tubes ....less ground clearance in illinois isnt what you want or need....LOL....now in st.louis it isnt quite as bad i guess but around here i wouldnt be running longtubes...LOL
Old Nov 3, 2004 | 09:05 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
well what shorts would you run then?
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Hedman LT's give the best ground clearance. Just get a copper or aluminum donut, do not get anything else.
Old Nov 3, 2004 | 09:08 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
hey general, whats your aim SN?
Old Nov 3, 2004 | 09:10 PM
THEGENERAL's Avatar
dont use aim
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
then sign onto your yahoo thats in your profile
Old Nov 3, 2004 | 09:16 PM
THEGENERAL's Avatar
alright ...im signed in
Old Nov 3, 2004 | 09:39 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
it dont show you as on, my yahoo name is jayannsilentbob
Old Nov 3, 2004 | 09:46 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Old Nov 3, 2004 | 11:56 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Most likely you don't have your exhaust hung properly, and the flanges aren't pulling up even all the way around when you've gotten them tightened down. One of mine blew out a few times due to this, finally ended up rehanging everything (my catback was kinda jury rigged up initially, resulting in poor fitament at the flanges by the time I got everything all contorted around to fit together at all...) and it's been fine ever since...
I don't know what else would cause it, it's not that complicated a setup.
Old Nov 4, 2004 | 01:05 AM
EvilCartman's Avatar
Car: '82 Z28
Hummm... the only donut gasket on my Edelbrock headers is on the drivers side. The other side is where that little exhaust flapper thing still sits and mates up with no gasket.
Old Nov 4, 2004 | 02:44 AM
Ray87Z's Avatar
Car: 94 Z28
Axle/Gears: 3.23s
Must be different part numbers or something, mine (I have a set on both my 87Z and my old 86 IROC) have donut gaskets on each side. Both are the TES systems listed for 86-92 single cat TPI cars, guess some others are different.
Coincidentally it was also the passenger side on mine that kept blowing out. I forgot to mention this was on my 87Z. I made sure everything was correct with the exhaust alignment on the 86 IROC when I put a set on it later and never had a single problem with it's gaskets...
Old Nov 4, 2004 | 05:25 PM
Marc 85Z28's Avatar
The TPI cars did not get the valve in the passenger pipe, therefore the Edelbrock headers designed for them are similar. They require donut gaskets on both pipes. The carbed cars did get the valve, and thus the Edelbrocks for the carbed cars use that setup, and do not need a donut gasket on the passenger side.
3 things to check for:
1. Do the pipes line up? They cannot be crooked, and they need to be near dead on even. If not, heat them up, cut them up, do what you need to do to get them to mate well
2. Make sure the outlets are clean and in good shape. Even the slightest bit out of round and they will not seal.
3. What hardware are you using? I had the same problem a while ago and it turned out to be the bolts. While to bolts were long enough, the shoulder portion of the bolt was too long and not allowing the flanges to pull together fully. I replaced the bolts with bolts that were fully threaded. When properly installed, only a millimeter or two of the donut gasket should be visible between the pipes. If not, the flanges will need to be tightened.
Old Nov 4, 2004 | 05:29 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
i fixed it,it turns out the damn bolt loosened themselves and the conjuction was completely separated. I am sooo tally pissed that i was so ignorant not to even look. there goes $12 bucks down the drain/
On the good hand, i went to a junkyard today and got the entire seat set out of a car for $20.Awesome deal. Was a steal. Gotta take the covers and put them in the washer now. TTYL.
Old Nov 4, 2004 | 06:20 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
on my 85 it still has the metal chunk that a flapper could of been in, it is what seals the stock set up. but i would expect thet the header is flanged and not flat like the stock connection.
Old Nov 4, 2004 | 06:56 PM
ljnowell's Avatar
And you were calling people a dummy earlier in the thread?
Old Nov 4, 2004 | 07:04 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
thanks for making me feel better d00d
Old Nov 4, 2004 | 07:13 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
lmao
Old Nov 5, 2004 | 12:49 PM
Marc 85Z28's Avatar
No big deal. You're not the first to do that, and certainly not the last.
Old Nov 5, 2004 | 01:09 PM
ljnowell's Avatar
Its alright, anytime. You know where to find us.
sheachopper
Jul 31, 2019 11:27 AM
Fanatic1074
Oct 2, 2015 03:47 PM
86IROC112
Sep 28, 2015 08:17 PM
Breazlan
Sep 25, 2015 11:20 AM
84redta
Sep 19, 2015 09:58 AM
