CAI Setup
Old Nov 3, 2004 | 09:53 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
CAI Setup
Ok my current CAI consists of a a gay Filter and what not.
I am wantingf to build my own Custom CAI right now.
Ok I want a K&N filter capable of flowing 1000CFM(that is if its needed) and maybe a 3-3.5" inlet.
What would be a good part number for such a filter.
Also, Should i get a different elbow, or ust attach the metal to the current elbow i got?
Old Nov 4, 2004 | 09:20 AM
Damon's Avatar
The stock intake on an 86 like yours is a nightmare- like it was intentially built to be as restrictive and complicated as possible.
I have on a couple of occasions ripped it all out and built it back up using an 88-up 90* Trans Am TPI elbow from the TB to the MAF, which is a much cleaner shot than the stock "boxes, accordians and elbows" setup. I recall I had to slightly re-route the MAF wiring to make it reach up to it's new location (which will be higher up and slightly closer to the center of the car). Beyond that, putting something on the front of the MAF to reach over to wherever you want to put the filer (usually near the pass. side fender behind the headlights) can be as simple as some cheap air duct hose all the way up to a custom-bent metal pipe with rubber flanges on either end.
BTW- SLP make a similar kit with everything you need for a Firebire/Trans Am CAI that is, in my opinion, a well thought out system, but a bit pricey. You might be able to find one used on Ebay, however.
Old Nov 10, 2004 | 07:35 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Re: CAI Setup
I had one of those on my car, but got rid of it because I'm homophobic.
Old Nov 10, 2004 | 10:11 PM
ljnowell's Avatar
How do you know that your filter is gay? Do you occasionally catch it in perverse acts under your hood? Is it perhaps fondling your oil filter when no one is looking? Be careful, it may even be violating your radiators filler neck when the hood is down.
Old Nov 10, 2004 | 10:12 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
its a filter i bought at walmart and the pipe is PVC.
Old Nov 11, 2004 | 12:16 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I have a 4" x 9" K&N cone filter at the end of some 3" and 3.5" PVC tubing and rubber hose. I think it looks very nice actually
Old Nov 12, 2004 | 08:11 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
maybe it just sits there and only talks to the other filters when noone is looking because its shy?
how can a filter be gay shane???
this is not helping you in your quest to become popular on herer...
please please please grow up and quite posting garbage like this
Old Nov 12, 2004 | 09:31 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I used a set-up from a MAF TPI Camaro. Then I gutted the whole thing and replaced the MAF sensor with a peice of PVC pipe and painted it black.
There was an article on oiled air filters (K and N) that you might want to read before buying a $40 air filter.
Old Nov 12, 2004 | 02:59 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
I patiently await the cardboard mock up.
Old Nov 12, 2004 | 03:18 PM
ljnowell's Avatar
Do you have some pictures of this shane??
Old Nov 12, 2004 | 03:33 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
nah its finished now. I went and got some cool stuff and remade the damn thing.
But i got one question while i was working i took out eh A.I.R. Compressor, and the A/C Compressor. All in the long i started up to notice this very weird vibration while inside the car.
Is it because i only have one of the power steering brackets connected?
shane
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
