Pushrod Length Question...
Old Nov 5, 2004 | 08:53 AM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
I just bought myself a set of dart iron eagle 180 heads for my iroc, and i wanted to know if anyone knows if i'd have to get new pushrods or if i can use the stock sized comp cam pushrods i have now (7.195)? someone told me they used their stock pushrods when they put on their dart ie 180's, but im not so sure if i'd wanna do that without hearing what other ppl have to say. does anyone know for a fact that i'd need different size pushrods? because i'd rather not go out and buy a pushrod length checker for 40$ unless someone can tell me they've tried those heads and had to get different sized pushrods. i know it would be best just to check it with the pushrod length checker... but i just wanted to see what you guys had to say since i probably wont be able to get one till next week or so. so yea, thanks for the help guys, i appriciate it
Old Nov 5, 2004 | 10:54 AM
Damon's Avatar
I've used Dart heads several times and always used stock length sticks without problems. There is nothing inherent in the Dart head's design that requires special length pushrods. Obviously, you need hardened pushrods to work with the IE's guideplates, but it sounds like you've already got aftermarket sticks (which are hardened).
Old Nov 5, 2004 | 12:16 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
yeah... my pushrods are hardened, but im using self-aligning rockers so i dont need guide plates.
Old Nov 5, 2004 | 01:29 PM
ede's Avatar
ede
heads have less to do with push rod length than cam lift and rocker ratio does. best thing to do is dummy a pair of vales up and check the length
Old Nov 5, 2004 | 05:34 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I totally agree with ede on this for no more than the plastic rocker costs and time involved to double check.
But, if heads are the only swap your making it should not be a problem. Usually you dont run into trooubles unless you start using different lifters, rocker arms/ratio's. Again, for no more than it takes to check, it's time well spend to be 100% sure. Hate to wipe out a cam or break valvetrain parts just "guesstimating"
Old Nov 5, 2004 | 05:44 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
hmm... i have a compcam 503 cam and s/a 1.6 rr's. ive checked out the valve stem tips and they look fine... i'll take a look at it tomorrow and tell you if anything's changed since i last looked... but last time when i took the heads off, the valve stem tips had a mark from the rockers in the middle. i guess ill see if anyone i know has one that i can borrow just to double check... but how exactly do you use a pushrod length checker? it's kind of hard to tell if the rocker is seated in the middle of the valve stem tip by looking at it... anyone know how to use the tool properly?
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
mfp189
Sep 27, 2015 09:25 AM
Scorched1984
Sep 15, 2015 03:42 PM
