Why does my car overheat? espeacally at high speeds
Old May 28, 2001 | 06:27 PM
86transamws6's Avatar
Car: 88 IROC - 86 Trans Am
Engine: L98 Carbed - 350 Carbed and boosted
Transmission: auto - T5
I put in a 180 degree thermostat, and put on a new airdam, cause old one broke in half and air couldnt get pushed into the radiator, both those fixes didnt make it run cooler at all. any suggestions on what to check next. oh ya the water pump is working cause when i turn on the heater it works fine. it runs at 260 when i go faster than 70
Old May 28, 2001 | 07:18 PM
Enkil's Avatar
I suggest you don't go 70 until you get this fixed.
I know it's a new thermostat, but are you sure it's working? It could be stuck closed and not allowing enough radiator fluid to go through.
Take it out and put it in boiling water, see if it opens.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old May 28, 2001 | 09:37 PM
camaro1j's Avatar
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
If it is getting hot at high speeds it is probably your upper radiator hose.
www.geocities.com/camaro1j/myz28.html
406
accel supper ram
6000 rpm Hyd roller cam
afr heads
spohn torque arm and crossmember
t-56 trans, [wier racing bellhousing and hydrolic throwout bearing]
9" ME rearend 3.91 Gears
Old May 28, 2001 | 09:42 PM
how would the hose make it overheat? im just curious im not arguing
Old May 28, 2001 | 09:44 PM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
get a new radiator.......thats what the problem is
<font face="Verdana, Arial" size="2">I have experience......unfortunatly its a result of bad judgement......</font>
click below to check out....
www.formula350.com
or click below to email me
webmaster@formula350.com
Old May 28, 2001 | 10:46 PM
FormulaGod's Avatar
i had the same problem. There is a shroud under your bumper. Its black and goes around the whole front clip of the car. If you cant find it its because its not there. Go to a dealer and get one quick. Our cars dont have grills to allow air to the radiator. the shroud under the car directs the air to the radiator. Get a 160* thermo too. The 180 is junk.
"Restore decency in America. Ban rice!!"
Moderator at www.Lastgen.com check us out!!
Old May 28, 2001 | 11:06 PM
Enkil's Avatar
Nonono.. He said he's already replaced the air dam. (That's what you called a black shroud.)
180 is more than enough to cool his engine. 160, in fact, would more likely than not be too much for his car. Unless he's done some extensive tuning to make use of that 160 thermo.
89 iroc-z 305 tbi
Old May 28, 2001 | 11:26 PM
AustinT's Avatar
I Also think you need a better radiator. I while ago back I Had a post that said "the faster I go the hotter it gets" My problem is the radiator. It really wasnt the speed I was going it was the Rpms. If I drop into 5th or 6th gear The temp Is oK but if I use a lower gear the temp will climb with the rpm's. Im trying to figure out wich radiator Is the best, so i can replace mine
Old May 29, 2001 | 12:04 AM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by camaro1j:
</font>
Actually, you might want to check the lower radiator hose. There is supposed to be a stiffener inside the hose to prevent collapse due to pump suction at higher RPMs. When the engine is cool, remove the radiator cap and start the engine. When it warms and the thermostat opens, you should be able to detect flow in the radiator. When you wick the throttle open, the coolant level should go down briefly from pump suction. If not, the pump impeller may be slipping on the shaft or the hose may be collapsing.
If you don't detect flow when it is warmed, either the new thermostat is not opening or you may need to reverse-flush the system and hope you get any contaminants out.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old May 29, 2001 | 06:30 PM
thanks a lot guys ill try that
Azrael91966669
25
Jun 20, 2017 04:04 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
