Gear Boxes and motor oil ?
Old May 29, 2001 | 08:57 PM
ede's Avatar
ede
i'm finishing up rrepairs to an 8 speed gear box that the maker says to use 30w motor oil in. i wonder if running 15-50 or 10-30 mobil 1 would hurt anything? thanks
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old May 29, 2001 | 09:32 PM
82camaro's Avatar
Car: 82 camaro SC
That's a good question! I've been wondering if I should run some full synthetic in my 70 cub cadet that calls for HD30. The old timers tell me HD30 only, but I think some Mobil 1 would work better.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old May 29, 2001 | 09:54 PM
Vader's Avatar
Ed,
Sorry I didn't have diagrams on your gearbox - all I could find was the 3/R non-synchro box diagrams. I'm guessing that either PAO or PE synthetic would be O.K. since you don't have any combustion going on, and as long as you don't have any sealing problems.
Multigrade shouldn't be an issue, since the viscosity of synthetics is a lot more stable. In case you don't already have it, I'm sending an oil interchange chart so you can specify the correct gear oil (synthetic) if you are concerned about extreme pressure lubrication.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
[This message has been edited by Vader (edited May 29, 2001).]
1992rs/ss
Jan 31, 2025 05:10 PM
eightsixseven
Dec 16, 2024 01:50 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Navy8125
Aug 21, 2015 09:32 AM
Street Lethal
Aug 13, 2015 08:28 PM
