Help! 350 TPI Bugs, timing and valves.
Old May 30, 2001 | 11:09 AM
KustomIroc's Avatar
Car: 1986 Pro Street Iroc-Z
Engine: 383 Stroker
Hi guys
Finally i put my 350 in and it worked great for about 2 days. I need to set the timing but have no idea how. I had to use the 305 balancer but am going to change it soon. i also used the 305 knock sensor with no problems. The questions I have are: I set at 0 top dead center but when I read the timing now it says 8???? Also how often do I have to set my valves before they won't need to be adjusted again? what is the proper way to set them? I made 2 passes at the tarck last weekend 14.69 @ 95 mph on the brakes I figure it would have run 14.4 or 5's. I need new wires now though.
Jamie James
1986 Iroc-Z 305 TPI
1.90 60 ft 14.15@ 95.75
1.74 60 ft 12.84@107.75 on the bottle.
My IROC:
http://personal.nbnet.nb.ca/jjames/homepage.htm
Old May 30, 2001 | 01:57 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
As far as i know if you have a Hyd cam then you only need to adjust the valves once. However you really need the 350 Knock sensor before you go too deep in the timing.
Brian
1989 Camaro RS
305 .030 over
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter Ultimate TBI mods...14X3 K&N open Element Non-Drop... LETS PLAY FORD!!
Old May 30, 2001 | 02:03 PM
KustomIroc's Avatar
Engine: 383 Stroker
I have a 2040 Crane compu-cam. Non roller.
I cross referenced the part number for the knock sensor for an 86 305 and an 86 350
as well as an 87 350 and they are the same part numbers????????
Jamie James
1986 Iroc-Z 305 TPI
My IROC:
Vintageracer
Jan 10, 2020 05:33 PM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
