EGR temp switch
Old Nov 10, 2004 | 01:23 PM
88Z's Avatar
88Z
Car: 88 Iroc
EGR temp switch
Did chevy decide to kill the egr temp switch on speed density TPI's? Finishing up my motor swap, and there's absolutely nothing there for the wire to hook up to. I was comparing it to my maf 305, and it looks like they didn't even make a port on the SD manifold for a new sensor to screw into.
Old Nov 10, 2004 | 01:56 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You are correct sir, the speed density engines do not have the EGR diagnostic temp switch in the EGR valve.
Old Nov 10, 2004 | 03:49 PM
88Z's Avatar
88Z
Car: 88 Iroc
So if I'm using a MAF ECM, I'm going to have to get a new valve, right?
Old Nov 10, 2004 | 10:02 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Are you running a MAF or MAP system? If you are running a MAP system then I believe that you should also have the MAP ECM to go with it.
Old Nov 11, 2004 | 12:28 AM
88Z's Avatar
88Z
Car: 88 Iroc
I'm running a maf system with a maf ECM, the intake is from a SD system though.
Old Nov 11, 2004 | 12:37 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The diagnostic temp switch goes in the side of the EGR valve, that is why you can't find it on the intake manifold.
Old Nov 11, 2004 | 01:56 AM
88Z's Avatar
88Z
Car: 88 Iroc
The EGR valve which attatches to the intake, right?
Old Nov 11, 2004 | 02:30 AM
Morley's Avatar
Yes, the valve goes on the intake and the switch goes on the valve....If your intake doesn't have the place for the valve to mount you may have an intake off of a corvette with alum heads.
Old Nov 11, 2004 | 10:56 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I think he has the valve Morley and has it mounted, he just doesn't have a place to put the switch because he probably has a speed density EGR valve installed.
Old Nov 11, 2004 | 02:19 PM
88Z's Avatar
88Z
Car: 88 Iroc
yes yes yes exactly. So I just have to get a MAF valve and all my problems go away? What exactly would it do without that connected?
Old Nov 12, 2004 | 01:40 AM
Morley's Avatar
It would set a code for EGR, it would send the signal to the solenoid requesting EGR but it wouldn't see the feedback telling it that the request was recieved and is functioning properly.
Old Nov 12, 2004 | 01:41 AM
88Z's Avatar
88Z
Car: 88 Iroc
translating into.....what aspect of my car is going to not act right?
Old Nov 12, 2004 | 03:47 AM
Morley's Avatar
When the ECM doesn't see EGR when requested the ignition timing is taken from a different table (or just pulled back some, not for sure on that one) and your performance will suffer a little.
Ghettobird52
Jul 5, 2024 11:18 PM
injdinjn
Aug 28, 2015 12:51 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
