A/C pressure switch location..
Old Nov 12, 2004 | 03:32 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I have recently removed bunch or wires after getting rid of my A/C and my fan keeps staying on way below fan on temps..
I read it somewhere that it has something to do with the pressure switch being open and computer thinks the a/c is ON.
I have a single fan setup..
PS. Where is that A/C pressure switch?? or where is it hooked up to?
Old Nov 12, 2004 | 04:33 PM
Vader's Avatar
Look at the refrigerant hard lines along the right subframe rail, just inside the spring tower. There should be a two-wire connector located there.
Old Nov 12, 2004 | 10:17 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I got it figured out. I disable the A/C pressure switch in the PROM and the fan is one more time working the right way.
Old Nov 12, 2004 | 10:32 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Ahh, eprom burning to the rescue...and you don't even have to get dirty hands. I wonder if there is "secret way" to control BOTH fans in 165 like there is on the 730. There probably is, just hasn't been found yet.
Old Nov 13, 2004 | 03:04 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I was amazed myself that it worked perfectly. It took me less than a 2 minutes to modify and burn a chip and it would probably take me hours trying to locate that stupid pressure switch or remaining wires and fixing it that way..
Old Nov 14, 2004 | 09:11 PM
4BoltMain's Avatar
Car: 2003 F150, 87 IrocZ28, 90 Camaro RS
Engine: 87 has 383 stroker, 90 has stock 305
Transmission: 87 has borg warner WC T-5, 90 has 700R4
the a/c high pressure switch is always on the high pressure a/c line.
Why did you take your a/c out?
You only get a slight loss of power when you have the a/c compressor on.
My fans work the way they should, but I also but a manual switch in there too for good measure.
Old Nov 15, 2004 | 10:45 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I took it out because where i live there i only like 3 weeks of really hot weater in the summer and the rest of the year is much cooler, plus little bit of a weight loss, and much more space to work under the hood.
Old Nov 15, 2004 | 12:18 PM
4BoltMain's Avatar
Makes sense man. It's hot here in mass for about 2 months in the summer. Sorry if I sounded like a jerk.
Old Nov 15, 2004 | 03:03 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
No worries
Old Nov 15, 2004 | 05:27 PM
Car: Death Mobile
Engine: 666 c.i.
I guess you must be at Edmonton (or north)...but yeah, A/C is only a "short need" event.
I've been tempted also to remove mine even though I am in Kamloops and it's "a/c weather from as early as mid-May to as late as mid-Sept". I just want to "clean up" my underhood and be able to get at things easily.
The car is no longer a "daily driver" and I have other cars that have a/c if comfort is a concern.
Old Nov 15, 2004 | 07:36 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I would do it Glenn. The difference under the hood is unbelievable. We don't live in Calofornia so I would do it. Mind you you get nice and hot summer in Kamloops.
I also got rid of the all emission crap including all of the air pump components. That cleaned up my engine bay even better..
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
TA8487
Aug 16, 2015 12:21 PM
