a/c delete box question
Old Nov 13, 2004 | 02:32 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
are the motors the same. also are the cages the same. the one that i have from the a/c box is to wide. i went to the parts store to get the a non A/C cage and the guy said that there was no listings, just a standard one. i told him that it was for an 84 camaro with a/c delete heater box, but no luck. let me know what you guys think.
Old Nov 13, 2004 | 04:02 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Your AC blower motor can be swapped to the non-AC box to save rewiring hassles, but you'll need a shorter fan, like you figured. Check for one to fit something like an Impala (Caprice), Cutlass, Regal, Monte Carlo, etc. I've read of some people making a spacer to sit the motor further out for clearance.
You might also have to modify the area where the resistor pack sits in the box, but I'm not sure as I haven't seen an AC box up close to tell - all 4 of my thirdgens were non-AC.
Old Nov 13, 2004 | 05:29 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Motors and cages are different anything you do to make an A/c blower motor fit will be custom
Old Nov 14, 2004 | 05:30 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
I made a 1 inch spacer out of billet aluminum....you could try doing something like that.
Attached Thumbnails a/c delete box question-000_0466ac.jpg
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
redmaroz
Aug 16, 2015 11:40 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
BikeFarm
Aug 11, 2015 11:35 PM
