Car won't start!
Old May 27, 2001 | 01:09 PM
Swoop's Avatar
Car won't start!
Hey all,
It's been a while since I've posted on here. I used to be into 3rd Gen's alot but then I ended up converting to the darkside and built a 9 second turbo stang that I compete in the NMRA with.
Anyways, I just bought an 89 IROC 350 from a police auction and I had it towed home. It won't start. The car has been sitting for over a year. I put a fresh battery in it and nothing electrical will work. The only things that will work are the horn, headlights, dome light, and gauges. I turn the key and I don't get anything at all: doesn't even try turning over, no power windows/locks/trunk.
The battery I installed is good, it works in my other car. So my question is: what do I do? It's been so long since I've worked on a thirdgen that I'm lost!
Mike
Old May 27, 2001 | 01:11 PM
Gta-Paladin's Avatar
Alternator? Starter?
Sounds like the alternator to me.
Can u jump it to start?
What is you voltage?
Old May 27, 2001 | 01:36 PM
Enkil's Avatar
Check all the connetions, mainly the ones from the battery to the alternator and the ones to the starter. You can start a car without an alternator, it just might not stay running too long.
Also, check the fusable links. They cause funktified problems sometimes.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old May 27, 2001 | 01:52 PM
Swoop's Avatar
Hmmm...
The thing that is confusing me is that the power accessories aren't working (windows, locks, trunk). I can't figure it out, lol.
Old May 31, 2001 | 07:32 PM
Swoop's Avatar
Any ideas?
Old May 31, 2001 | 07:49 PM
TOM305T/A's Avatar
Car: 1987 GTA 350 auto
Check fuses, especially the ecm fuse
Old May 31, 2001 | 08:38 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
CTSY fuse and probably another one or two. I'd also check the ground on the block and the wiring to the dist. Some PDs, on impound vehicles over a week, disable the coil or distributor.
"Question with boldness even the existence of a God; because, if there be one, he must more approve of the homage of reason, than that of blind-folded fear."
-Thomas Jefferson
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
