Ignition Coil is riveted in?
Old Nov 15, 2004 | 08:51 AM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
1989 2.8L V6. I have a bad coil. I buy a new coil, plug it in, test it, problem solved. Great.
What the? Are those rivets? My *** what kind of a sick joke is this?
It would appear that my coil is held in on the 4 corners by 4 rivets. There is no apparent way to undo them. The little brackets my new coil came with seem to correspond with the old ones, but where I have bolts, it has rivets.......
Is this stock? Or some sadistic mechanics idea of a joke?
Old Nov 15, 2004 | 09:02 AM
ljnowell's Avatar
Die grinder to the heads of the rivits, and install long skinny bolts with nuts on them. It sucks, and it pissed me off too.
Old Nov 15, 2004 | 09:17 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
What he said!!!!!!!!!!
Old Nov 15, 2004 | 09:19 AM
bobdole369's Avatar
Car: 1989 Firebird
OK
As long as it's not just me Thought maybe some mechanic put them in before I got the car as some kind of way to keep the customer coming back.
OK, think my dremel's got what it takes? or should I borrow my wifes dads hammer drill?
Old Nov 15, 2004 | 09:27 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You can knock them out with a regular hammer and a small pin punch. This was the way that GM made the ignition coils back then.
Old Nov 15, 2004 | 11:56 AM
bobdole369's Avatar
Car: 1989 Firebird
Shudders
What were they thinking? Well I guess it makes it so I might want to buy a new one
Old Nov 15, 2004 | 09:04 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i use a chisel to cut the heads off & then the brackets lift pretty easily
Old Nov 15, 2004 | 11:31 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
A drill with a bit just wider than the pin works great to remove the head, but I suppose a die grinder or Dremel would work just as well.
Old Nov 16, 2004 | 10:57 AM
bobdole369's Avatar
Car: 1989 Firebird
Thanks for all the suggestions guys, I'll get over to a spot where I can get an extension cord out to it this weekend, and either drill it or dremel it out. Thanks again
Old Nov 22, 2004 | 03:20 PM
bobdole369's Avatar
Car: 1989 Firebird
Drats!
Foiled again!
Well not to turn this thread into something besides the subject, I'll start a new one.
Old Dec 13, 2004 | 09:06 AM
bobdole369's Avatar
Car: 1989 Firebird
Resolved.
Rivets removed with a combination of tinsnips, wirecutters, channel locks, needle nose pliers, and linemans pliers.
Metal was easy enough to tear up enough to get it to push out the other side.
Mostly due to my lack of ability to get an extension cord out to my car. (We don't have garages in south florida LOL)
Old Dec 13, 2004 | 10:28 AM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
use a hammer and chisel thats what i did when i put my msd coil in
Old Mar 27, 2005 | 10:04 PM
GravyGut's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: Auto w/ overdrive
Dude, its allot easier to take the coil out of the car before you work on getting the rivets out.
Old Mar 28, 2005 | 11:51 AM
ljnowell's Avatar
Depends on my 2.8 it was going to be a long job to get the coil bracket off. Just hit it with a die grinder and pulled em out. Took about 5 minutes to remove and reinstall.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
