unidentified bracket
Old Nov 15, 2004 | 08:05 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
Can someone tell me what this is, and where it goes?
Old Nov 15, 2004 | 08:41 PM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
Alternator bracket.. it goes on the back of the alternator where the long bolt goes through the alternator, then through the long spacer on that bracket and into the head.
the other end bolts to the back of the alternator.
I don't know if it's used for serpantine setups, but I had one on my V-Belt setup.
Old Nov 15, 2004 | 08:55 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
i've got a vbelt setup as well....
do you by chance have a pic of this bracket in use?
i thought it went in back, but couldn't see where the whole thing went
Old Nov 15, 2004 | 09:38 PM
My car is torn down at the moment, I can only basically tell you where it went as I did above, If no one else has a pic, I will dig out my alternator and take a picture, but it won't be until tomorrow or the next day.
Wish I could be more help.
Old Nov 16, 2004 | 05:54 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Attached Thumbnails unidentified bracket-alternator-bracket-spacer-washer.jpg
Old Nov 16, 2004 | 08:27 AM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
I think this for air pump on V belt
Old Nov 16, 2004 | 08:29 AM
the air pump is below that, if you look closely at the picture you can see that. RB posted a great picture, you can see where it goes, now the other end bolts on the back of the alternator...
Old Nov 16, 2004 | 04:23 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
awesome...thanks for the pic rb!:hail:
Old Nov 16, 2004 | 11:50 PM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
I know that but I am almost postive I saw the same bracket at air pump
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
meeklay812
Oct 1, 2015 03:46 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
armybyrd
Sep 26, 2015 03:37 PM
