identifiying block...
Old Nov 17, 2004 | 03:33 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Ok, i know that if you know the casting number you can identify the block....BUT
can you identify the block casting by the vehicle? Are there any castings that are vehicle specific? or and vehicles that are casting specific?
I know the truck is a 78 3/4 ton pick-up, it has smallblock 400 and a th400. Is there anyway to tell the casting number by just having the model and make? What are the chances its a 509 2-bolt?
OR do i have to dig thru the crud and look for a casting number.
Old Nov 17, 2004 | 03:37 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
only way to know for sure is clean the crud off and get the casting number.. knowing what its in can give you an educated guess as to what you have but theres really no way of knowing what it is for sure without actually checking the block.. think about it, after all these years it may not even be the origional engine..
Old Nov 17, 2004 | 03:39 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The only thing that links a specific vehicle with a specific block is the numbers stamped onto the waterpump mount on the front pass side of the block. Those numbers will tell you what the block came out of (ie. '78 pickup) and its original configuration (ie. 180hp 400ci).
You know how you always hear about the old 302s for the Z/28s being "DZ motors"? Thats what they are refering to... "DZ" was one of the numbers stamped into the waterpump mount, and that made that block specific to a Z/28 Camaro, and not a truck or Corvette, or an SS Camaro, or whatever. Only a Z/28 and only in 1969.
Old Nov 17, 2004 | 04:07 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
looks like im going to be scraping crud..its ok i can get the whole truck for a couple hundred
Old Nov 19, 2004 | 09:14 PM
305Camaro84's Avatar
Car: 1894 Camaro Berlinetta 305 auto
Engine: 305 LG4
Transmission: TH 700 R4
engine
im just curious to know if my engine is original, where can i find the engine # i would think it would be on the block but i looked and from what i could see... well i really cant see any #s or anything
Old Nov 20, 2004 | 12:28 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
www.mortec.com
Old Nov 21, 2004 | 05:53 PM
Air_Adam's Avatar
Re: engine
Look on the machined pad infront of the pass side head. Should eb right under your alternator.
Old Nov 21, 2004 | 11:32 PM
forums_suck's Avatar
Car: 1983 Z28
Engine: 383
i know when i was routing through the boneyard for a rebuildable small block some of them had the last three numbers ie 509 right near the engine mount on the block.Sometimes it easyer to read then like you say scrapin all that crud off the back hehe i hate that too
88fastgta
Feb 4, 2009 08:49 PM
dalunchbox18
Dec 19, 2008 06:19 PM
aged 86 transam
May 20, 2008 05:45 PM
redraif
Dec 16, 2004 11:35 AM
cfabe
Apr 28, 2004 12:30 PM
