Heads
Old May 31, 2001 | 10:19 PM
MADOGIROC's Avatar
Heads
Ok I got 89 Iroc with 350 and my heads went to hell. My car is completely stock. Should I buy performance heads or just save up and get a performace ENGINE!
Old Jun 1, 2001 | 04:11 AM
ede's Avatar
ede
aftermarket heads won't do as much on a stock engine as they would on a modified one. what you do all depends on what you want and can afford. if you don't change anything i'd get the stock heads reworked.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jun 2, 2001 | 06:39 PM
lukerene's Avatar
Car: 1982 t top,,z/28,
Engine: 409ci vortec
Transmission: all steel t700r4,1300 stall yahooooooooooo
putting a higher flowing head on a stock engine,,wont do much,you must go in stages,,if it breaths better,it must must be able to get it out better,IE; exhaust,,if you change the heads,especially on a stock 305,,you should go up one stage in the cam,and exhaust,,,and use a high flow AIR CLEANER,, a stock 305 has good torque,,with the stock heads,and exhaust manifolds, the only way to improve the 305 is with shear cubics,,and $$$$,the 305 has a good bore and stroke,,and is a good little package, HEADERS wont make the car go faster,,torque is what PULLS not horsepower,,the story is endless,,DO IT IN STAGES,GOOD LUCK
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
