Needle Adapter for Greasing U-joints
Old Nov 22, 2004 | 12:26 PM
GTA88's Avatar
Hi,
I have a greasable u-joint in my car. But I can't get to the zirc fitting with a regular grease gun fitting. Supposedly a needle adapter is the way to go. I don't want to stab it into the 4 rubber seals, though. I've heard you can insert the needle into the zirc fitting and lube the joint that way, but it doesn't make sense to me. How could there be any pressure into the joint, since the needle would leave space for the grease to ooze out of the zirc ?
Old Nov 22, 2004 | 12:34 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You shoot the grease into the Zerk. You hold the needle tight up against the Zerk, so that it more or less seals up against it. It's not a "needle" like you'd stab it through the rubber dust seal or anything.
It's supposed to be possible to get to those with a straight grease gun end, if it's rotated the right way. If you can't, then somebody put it in wrong; they weren't paying attention.
Old Nov 22, 2004 | 06:10 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You gotta press the needle into the zerk untill you feel it 'click'
Then shoot away. You should be good when you hear little popping sounds coming from the U-joint.
Old Nov 22, 2004 | 08:28 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Maybe two different things here. There are grease needles that are really needles. Also there are U-joint needles that fit up against the grease zerk and will get into the joint.
Old Nov 23, 2004 | 08:03 AM
GTA88's Avatar
Thanks. Yes, it's the blunt u-joint needle I need, apparently. The parts stores guys were telling me to use the sharp needle to get into the Zerk.
InfernalVortex
Apr 20, 2021 11:31 AM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
