wireing up a alternator in a 92
Subscribe
Jun 3, 2001 | 09:20 PM
i was wondering if any one can tell me the right way to hook up an alternator in my 92 camaro
a freind of mine took out a 2.8 engine and replaced it with a 305 out of a 92 and hooked everything up for me the alternator worked fine for about a year then went out i got another one and hooked it up worked for a couple of hours then went through 4 more before it finally worked right ( i wired it up three different ways then a professional wired the fourth one up) for about another year now im going through the same problem again ( i also have a 8 hundred watt amp and four tens in the back to) the alternator is a ac delco from usa but luckily its lifetime warranty
Reply 0
Jun 3, 2001 | 10:44 PM
That amp's not helping at all.. You might want to hook up a second battery.
SPeaking of which, dying batteries will kill alternators pretty quickly.
It's hard to hook up an alternator the wrong way, you plug the connector in, and you screw in the line running from the battery to the back.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Reply 0
Jun 4, 2001 | 12:10 AM
I'd say that if it lasted you for a year you're doing damm good!
Go to the audio board and see about extra batteries(as already mentioned), and even lightning caps and what not. I have a buddy that toasted a delco alternator in a couple months just because of the stereo.
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Reply 0
Jun 4, 2001 | 06:38 PM
okay un hooked my amp and speakers and then hooked up the alternator crunk up the car and it showed nothing unplugged the connector and the alternator started working then killed the car and crunk it up again same thing nothing till i unplugged the alternator and plugged it up again (same thing happened to a few of the other alternators to
89 camaro
carburated 305
bored .030 over
flat top pistons
bigger valves
heads and block shaved
spoiler
tinted windowshuge white chevy symbol on back
92 stock rims
92 ground effects
www.geocities.com/thirdgenerationcamaro
Reply 0
Jun 4, 2001 | 07:16 PM
okay i killed my car and le it sit for 30 minutes. went and crunk the car. as usual nothing. unplugged it and plugged it back in. nothing. yet another alternator fried i think that makes like 10 or 11 alternators so far.
89 camaro
carburated 305
bored .030 over
flat top pistons
bigger valves
spoiler
92 stock rims
92 ground effects
Reply 0
Jun 4, 2001 | 08:00 PM
you should just chuck the stock alternater,,and buy a 110 amp one wire alt. from jegs.Just hook up the 1 wire to the batt. and your good to go,,,,,,
they have the east coast alt.'s 110 anp alt for 199.00...not a bad investment...
I have one and i have 4 10's also,,,with an orion 1000 watter..not had 1 problem since...
Reply 0
Subscribe
