starter problem
Old Nov 23, 2004 | 05:21 PM
350WHT's Avatar
Car: 1992 camaro RS
Engine: sbc 350
Transmission: th350
starter problem
I need help with this ive replaced the stater over 5 times in my car. It starts out turing the enigne over fine then it will start missiing the flywheel put a shim in it just fine for about five times of use starts getting stuck its been the same thing everytime throw me some ideas PLEASE I DONE EVERYTHING I CAN THINK OF AND I NEED SOME HELP WITH THIS THANKS
Old Nov 25, 2004 | 08:34 AM
Vader's Avatar
350,
Missing the flywheel? As in "not engaging and spinning freely", or just spinning with a lot of gear noise? Is the starter assembled tightly? Is the nose piece loose from the starter motor? Is the fork worn?
You'e on the right track, but need to check alignment as well as pinion depth. Some earlier blocks had problems with the starter mounting hole locations, but I believe most of those were solved by the early '80s. If you have an older block, you might have one of those "problem children".
Of course, the distance between the pinion and flywheel is important, but you're better off with a little extra gap than a tight gap.
Oh, and your signature. You'll have to alter it a bit. As you might remember from the Membership Rules, words that are potentially offensive should not be part of posts, thread titles, or signatures. Try "rectum" or "sphincter" instead. I don't own the words, so you can use them freely. Trust me - We'll still get it.
Old Dec 4, 2004 | 01:53 PM
350WHT's Avatar
Car: 1992 camaro RS
Engine: sbc 350
Transmission: th350
if it is one of those problem children how do i fix it?
Old Jan 5, 2005 | 08:05 AM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
http://www.carcraft.com/howto/2988/index3.html
Old Jan 7, 2005 | 03:11 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
So is your problem child still having a problem, what was the actual fix if not alignment/spacing?
Old Jan 7, 2005 | 06:38 PM
350WHT's Avatar
Car: 1992 camaro RS
Engine: sbc 350
Transmission: th350
well its still having problems i really dont want to take the entire engine out and have it fixed i called a local machine shop in my town and they didnt have any idea what i was talking about.do u have any answers, ive done almost everything i can think of.(post up or pm me if u have any ideas)thanks steve
Old Jan 7, 2005 | 06:47 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What motor exactly do you have? Block casting number would be ideal. "Stock" won't do any good.
Old Jan 7, 2005 | 06:50 PM
350WHT's Avatar
Car: 1992 camaro RS
Engine: sbc 350
Transmission: th350
well its a 350 i dont have the casting numbers with at the moment, its been bored .60 over has preformer manifold, flowtec headers a beffed up cam not sure what size it is right off hand, has accel hei ingition and a holly 600 carb backed by a 350th tranny
Old Jan 7, 2005 | 06:54 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Did you check the flywheel to see if some of the teeth are worn downin one spot?? If you have one bad spot in the flywheel it may start fine a couple times until you hit the bad spot. You should be able to see it with the inspection cover off of the trans.
Old Jan 7, 2005 | 06:56 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Perhaps I should add, "a 350" and a description of the exhaust and stuff, isn't real helpful either.
If you can get a casting number, it will help figure out if you have one of the blocks with The Problem. Which in turn will help figure out what to do about it.
Get the casting number and post it.
Old Jan 7, 2005 | 06:57 PM
350WHT's Avatar
Car: 1992 camaro RS
Engine: sbc 350
Transmission: th350
ok ill get the numbers tonight and pm them to you tommorrow is that ok?
Old Jan 7, 2005 | 07:01 PM
350WHT's Avatar
Car: 1992 camaro RS
Engine: sbc 350
Transmission: th350
the flexplate is fine i took it out and theres not a scratch on it ive used every shim there is i havent got anywhere, that was my first guess.
Old Jan 7, 2005 | 07:20 PM
Lo-tec's Avatar
Did you measure the clearance between the flexplate and the starter? If your clearance is too large you can cut a shim in half and shim the outer bolt which should decrease the clearance.
Old Jan 9, 2005 | 02:50 PM
350WHT's Avatar
Car: 1992 camaro RS
Engine: sbc 350
Transmission: th350
yeah ive done that i didnt measure it though but i cut the shim in half and tried it on both bolts but that didnt help either!!
Old Jan 15, 2005 | 05:34 PM
83 Crossfire TA's Avatar
Ok, before anyone wastes any more time… Open your FSM or hanes or anthing like that and take a look at the proper procedure for shimming the starter. Hell, pry the pinion forward and check how much clearance it has when it’s engaged and then shim accordingly.
Essentially you’re telling us that you’ve tried some random shimming and it didn’t help. OK… that’s nice, how do you expect us to help you if you don’t want to check and we can’t see what is going on?
Spyder_TheGamer
Dec 25, 2015 05:07 PM
5spdcamaro
Aug 28, 2015 02:12 AM
92camaroJoe
Aug 13, 2015 06:07 AM
milk
Aug 10, 2015 06:26 PM
