Advanced Timing!!!!
Old Nov 24, 2004 | 11:58 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Advanced Timing!!!!
Right now i have my car at 0* but i see guys advance there timing?? what will i gain if i do that and where should i put the timing mark at?
Old Nov 24, 2004 | 12:01 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Usually a little improvement in throttle response, sometimes an improvement in power and fuel efficiency. However, it can have a negative effect on emissions (primarily NOx), so be sure to set it back before you go in to get it smogged.
Try 6 degrees BTC as a starting point.
Old Nov 24, 2004 | 12:03 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
but how much should i set it at.... thats crazy how you can advance it and get more power out of it. will i feel an improvement?? thanks for the reply
Old Nov 24, 2004 | 12:05 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
sorry i didnt see the bottom part... so 6 degrees is where i should start? is it marked on my timing braket?
Old Nov 24, 2004 | 01:02 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
6* is a good place to start, but I'd just set it to where the engine likes it (where it seems to idle smoothest)
Old Nov 24, 2004 | 08:04 PM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Re: Advanced Timing!!!!
The best timing is where you can run WOT and not encounter detonation. Six degrees is stock, on my 5.7 TPI cars, using 92 octane and 8-degrees works best -- no pinging, 20 mpg in town, 26 on the highway. and I noticed an improvement in acceleration.
Old Nov 24, 2004 | 09:14 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
had the timing light on my car and running 89 octane i have the base timing set at 12*, car loves and i love the mileage, 23 mpg mixed highway/city.
Old Nov 24, 2004 | 09:17 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
so you think i should just see where my engine likes it at. probaly at ill have to try 6 and 8... what do you mean by detonation.. like running really cheap gas kinda thing??
Old Nov 25, 2004 | 12:12 AM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
is your car have a cc hei if so you gonna have to put t in base timing mode so disonect the 4 pin conector and it'll go into base timeing. this is so your comp will not adnavce and retard the timing while the engine is at idle i would set it at about 10. if ping accures retard about 2 deg intervles till goes away
Old Nov 25, 2004 | 07:33 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
For a 305 TBI, 0* is stock. Just so you know, a lot of guys with TBI cars (including me) find that 4* advanced with 87 octane is the sweet spot for these motors with better throttle response and power, but without detonation. The timing tab should go up to at least 8*, but I can't fully remember right now. But, of course, every car is different, so set yours accordingly.
Old Nov 25, 2004 | 07:41 PM
jase's Avatar
I have a question.With 4 degrees advance,can i see an improvement in gas milage as well?
Old Nov 26, 2004 | 01:03 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Possibly. Stock tune on a tbi car has lots of room for improvement. Dont go overboard with the timing, of course. Try adding it in two degree increments and see what feels the best.
Old Nov 26, 2004 | 01:05 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Re: Re: Advanced Timing!!!!
Pinging is near impossible to hear on an efi car. If its not real severe, the computer catches it before it becomes audable.
Old Nov 26, 2004 | 08:43 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Re: Re: Advanced Timing!!!!
Sure it does. Two of my pistons would like to have a word with you over this theory, they fully dissagree. Infact, they feel, like many other racers, that the knock sensor is absoutely useless at WOT because it can't possibly bring the timing back quick enough.
The knock sensor is useful for crusing and say you go up hill and the car pings a little. At WOT, better learn to tune your car.
-- Joe
Old Nov 26, 2004 | 01:39 PM
Car: 88 Camaro SC
Engine: SFI'd 350
That was more in reference to stock engines, not super hot high CR big cam modified stuff. There I wouldnt trust it...
Ive had three stock engines (3800's, 4.3L) that had audable detonation problems. On one it was due to excessive mechanical noise overhwelming the sensor, and *** knows what else. That engine ran for 60,000 miles like that, constantly detonating. That thing sounded like a diesel in hot weather. Had really good power, though
On the other two it was a blocked egr and excessive carbon build up. Computer just couldnt pull enough timing to stop it. The engines ran like crap, obviously since the timing was constantly being pulled.
On the camaro Ive never heard it detonate unless its performing the forced engine knock test. With the base time set at 20 deg BTDC when I first put the motor in the total timing at high load during the test was around 45-50 degrees, which gave audable pinging.
Its not fool proof, but on a stock engine it can give the computer some measure of control and allow it to stop detonation before it gets out of hand.
Old Nov 27, 2004 | 03:34 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Re: Re: Re: Re: Advanced Timing!!!!
Why does the car ping going up a hill? Mine does this.
Old Nov 27, 2004 | 03:52 AM
sr.bond's Avatar
Car: 1982-z-28.1987 sc
Engine: 350 on z-28,305 on sc
Transmission: bw t-10 on z-28,700r4 on sc
another cheap way of knowing if the timing is too advanced is noticed at starting up,if the starter seems to hesitate(engine kickin'back the starter)then your timing is overadvanced.
to the guy that said his car pings while going uphill,that means you are either using cheap fuel or you have to much timing,try retarding the timing a little and check it out,or even better,use premium fuel
Amillionoh7
May 24, 2020 08:01 AM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
djmarch
Aug 9, 2015 05:27 PM
