Removing AC..worth it?
Old Jun 3, 2001 | 09:12 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I was thinking about removing the AC from my firebird. I only cruise it once in a while and to the track...always have the windows open. How much weight does it save? Anyone done it and put the GM pulley on with the non-ac box? does it look like factory?
Steve
Old Jun 4, 2001 | 12:06 AM
leirch's Avatar
I'm actually in the process of doing it right now. I'm getting a non-ac box , i'll have to get pictures of when i get it in(which won't be for a week or two atleast...). I don't have to worry about the delete pully though(87, v-belts baby!).
But removing it will save an EASY 25-30pounds, i don't think the weight was my deciding factor, it was the ability to actually WORK on my motor...
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Jun 4, 2001 | 07:13 AM
Brian K's Avatar
Don't unless your a serious racer... Who wants to buy a car with no AC if you have to ever sell it..... Plus one day it will be very hot and you won't be feeling well and the AC will be nice... If it is working keep it.
Old Jun 4, 2001 | 07:28 AM
JPrevost's Avatar
Car: 91 Red Sled
I agree with Brian. Only hardcore guys that don't have working ac get rid of it. Us normal folk like our creature comforts. I kept ac just for kicks, had to use it a few times already because of this funky spring we're having in Ohio.
, Jon (350 TBI!)
91 Red My website
Old Jun 4, 2001 | 07:40 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
does you A/C work?if it does?keep it!!!!you get the same wheather that we do here in cincy.hot *** sticky summers
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Old Jun 4, 2001 | 08:50 AM
Enkil's Avatar
Personally I'd keep it. It IS possible to build a car that's faster than most things on the road and still have the "luxury" items.
However if you're one of the hardcore racers, go for it. Every little bit helps, and it certainly is weight reduction. (I think I read somewhere that it's 35-40 pounds? Something like that.) It definately cleans up the engine compartment.
Just keep it in storage somewhere so if you DO sell the car you could hook it back up.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Jun 5, 2001 | 09:45 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I don't have my A/c anymore.. if I used it once a summer, it was a lot. (I love the heat.) Anyway, when I got into my accident, the freon line cracked, and gave me the excuse I needed to pull it. So, it all went above the garage, with tape over the fittings. I've yet to swap my heater/evaporator box for a non-ac heater-only box, though.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jun 5, 2001 | 11:20 AM
Greg '85 T/A's Avatar
Car: 1985 Trans Am/WS6
Engine: 5.0 TPI
Do you have T-Tops? I know my car gets HOT if its sunny out and they're still on. I'd keep the air. I removed it on my '73 Grand Am and regretted it.
-Greg
'85 Trans Am - WS6,TPI:
Original owner, original paint/engine/interior, plus the usual bolt-ons
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
