Lets hear your Head/Cam/Intake/Carb combo's..
Old Jun 4, 2001 | 05:25 AM
mrgto's Avatar
I am going to buy a 1982 Camaro and am going to add heads, cam and intake along with a new carb. I was leaning toward the Holley Systemax package that advertises 425hp. I am sure that is a liberal number. But it seems the cheapest way to go.
I was just curious if anyone could share their combo's and if they have any strip or dyno numbers to compare.
Thanks.
Old Jun 4, 2001 | 05:52 AM
LottaBallsCamaro's Avatar
Stock/Stock/Stock/Stock.....I'm sure they ran insanly high commpression to get those numbers.
Old Jun 4, 2001 | 05:58 AM
mrgto's Avatar
<font face="Verdana, Arial" size="2">Originally posted by LottaBallsCamaro:
Stock/Stock/Stock/Stock.....I'm sure they ran insanly high commpression to get those numbers.</font>
10:1 compression is insanly high? The heads flow more CFM than LS1 heads. The cam is more radical than a LS1 and it has a carb, which will usually make more HP than EFI. Obviously the fuel economy will be better on the LS1.
Old Jun 4, 2001 | 10:36 AM
RSR's Avatar
RSR
I run a stock LT1 shortblock with:
- LT4 heads
- GM LT4 dual plane intake
- GM LT4 HOT cam kit
- Demon Mech Secondary 750CFM Speed Demon
The car has a 3500 stall lockup converter, and 4.10 gears. It has run as quick as 12.30, and usually runs 12.35-12.45. It needs a taller gear, as the current setup forces me to shift into overdrive just before the end of the 1/4.
I drive it to work everyday, until I get my other car fixed...It gets about 20mpg on the interstate with the converter locked, but gets much, much less around town!
RSR
Old Jun 4, 2001 | 09:56 PM
Chill yourself boy.
Old Jun 4, 2001 | 10:10 PM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
read signature, add dart iron eagle heads, (150 shot of go go juice) running 11.12 best.
85 IROC 350 11:1keith blacks,.555lift erson roller cam,1.6 crane roller rockers,edelbrock intake,holley 4150 750dbl pumper, nitrous oxide,full length heddman headers,true dual exhaust, 11"stall converter, 700R4, 3.73 locker, certified engine and electrical systems mechanic
Old Jun 5, 2001 | 05:10 AM
mrgto's Avatar
Chill yourself boy.</font>
Well, if you had given me a half way intelligent answer then I would have. But seeing your username and your car are off about 180*, you really don't have anything useful to add, do you?
I am not going to use a LT1, so that is out as are the heads.
The engine that is in the car is a 350 and unknown heads, intake and carb. I won't be able to see it until sunday. The holley package is looking better and better.
Old Jun 5, 2001 | 08:01 AM
FastBroker's Avatar
Make a "fake" ZZ430! Use a nice 350cid shortblock, L31 Vortec heads with upgraded springs and screw-in studs, then the Hot Cam with 1.5 or 1.6 SA roller rockers (get Hot Cam Kit?), RPM intake or RPM AIR GAP, 750 cfm carb, nice headers. The ZZS430 got 430 hp (duh) with this stuff and Fast Burn heads and I am told that you can get 380-390hp with out-of the box Vortecs warmed over as I stated and the rest of the stuff. That's not bad and is CHEAP! Oh, make sure your HEI curve is right, too and tune the carb impeccably!
Old Jun 5, 2001 | 10:00 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
you can also go the homebuilt fastburn 383 route. Its a 383 with GM-FB heads. Add a hotlt4 cam and you should be up near 420-430 hp.
I would go not go with the entire systemMAX kit. Just the heads. The cam is only so-so.
Old Jun 5, 2001 | 11:40 AM
cvpde37's Avatar
Carb=750 DF DP manual secondaries
Cam=Comp Cams 507/292/242 @ .050
Heads=Dart Sportsman
Intake=Performer RPM
I bought the engine complete and probably would have went with AFR heads. The engine flywheel dyno'ed at 400hp and has run a best of 12.69 @ 111. I don't think the systemax looks too bad, I'm just not a big fan of edelbrock heads.
1984 Z28 350
Never argue with an idiot, they'll just bring you down to their level and beat you with experience
My Web Page
Old Jun 5, 2001 | 12:27 PM
FastBroker's Avatar
JCB, that route IS better but also $1000 more costly... But better and cooler, for sure, with the Fast Burn Al heads. Lighter, to boot! os should I say carry. ouch
Old Jun 5, 2001 | 01:08 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
i did not read too close before, if your going to stick with 350, you really need to try to find out a couple of things
<UL>[*]what your overall weight is (and what it will eventually be)[*]what gear you going to have in it.[/list]I have seen 350s with AFRs and a comp Hydroller 304 (600 lift -244 at 050), that would really scream. But it will need at least a 410 gear and about 3300lbs.
[This message has been edited by jcb999 (edited June 05, 2001).]
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
Fanatic1074
Oct 2, 2015 03:47 PM
sjorgens
Oct 1, 2015 07:54 PM
